State line
7 Users
I have two monuments set purportedly on the state line in 1954. I located the two MP monuments and then the two 1954 monuments. I calculated the intersection points at the two monuments and put them into my drawing and found.?ÿ
The west of the two monuments is 0.04' north of the state line.
The east of the two monuments is 0.003' north of the state line.?ÿ
By my calculations anyway.?ÿ
I guess my work is done once I re-dimple them.?ÿ
Posted : January 27, 2023 1:39 pm
I think a rebar and plastic cap online next to the monuments should do the trick.
Posted : January 27, 2023 1:45 pm
(@kevin-hines)
The earth only shifting 0.04' at your western limits over the past 69 years is phenomenal!?ÿ It just goes to show everyone that our predecessors knew what they were doing and we don't need to correct their work!!!!!
Thanks for sharing.?ÿ?ÿ
Posted : January 27, 2023 1:50 pm
Those guys killed it everywhere I'm retracing them. It's humbling when you realize how they were doing it.?ÿ?ÿ
Posted : January 27, 2023 2:00 pm
DO NOT UNDER ANY CIRCUMSTANCES LET ANY LOCAL POLITICIAN LEARN OF YOUR DISCOVERY.
Posted : January 27, 2023 2:02 pm
(@frozennorth)
No need to re-dimple 'em, save yourself a field trip.?ÿ Just call them witness corners on the plat, be sure to show the witness distance.
My work here is done. ?????ÿ
Posted : January 27, 2023 2:04 pm
Great Idea ?????ÿ
Posted : January 27, 2023 2:21 pm
I wouldƒ??ve thought the boundary would be controlled by the monuments and which are without error, so methinks youƒ??ve effectively shifted the boundary of two states and there will be consequences.
Posted : January 27, 2023 3:07 pm
Pffft. Check out the common corner of Oklahoma, Missouri, and Kansas.
Posted : January 27, 2023 3:25 pm
Of course it's the GIS Location
Posted : January 27, 2023 3:28 pm
@norman-oklahoma?ÿ
https://www.roadsideamerica.com/tip/50144
Posted : January 27, 2023 6:34 pm
It truly is somewhat uncommon to be able to stand at a tri-corner as shown above.?ÿ Typically because there are so many States having a river as a boundary.?ÿ For others, it is because some sort of barrier prevents human access directly to the true tri-corner monument.
The Kansas-Oklahoma-Colorado tri-corner is effectively a manhole lid with a design of the States on it (when oriented properly.?ÿ Below the lid is the true monument.
The tri-corner of Kansas-Nebraska-Missouri would be a challenge considering it is somewhere around the center of the Missouri River about a trillion miles from where it starts.
Posted : January 27, 2023 6:39 pm
