Hello guys!
Just wondering if anybody has tried to create a measurement line in Star*Net with F2 (reversed scope) information.
Thank you and regards.
Arnel
> Hello guys!
> Arnel
Won't work (at least for me and star*tds), you have to go in there and manually edit the degrees portion of the reversed reading in order for it to recognize it.
Ralph
Hi Ralph,
Zenith data type supports inverted values. Star*Net can automatically recognize zenith angle values. Unfortunately, it appears that turned angle data type doesn't support inverted values. What I do is manually edit F2 turned angle values. This is a painful approach.
> > Hello guys!
> > Arnel
> Ralph
What's the idea of using missing values? Is it really an intended move or from field data? Thanks.
No, the gun was not set up to take distances in F2, it is actual field data. I have gone over this (F2 angle) issue with Star*Net tech support and they are working on a fix. I'll keep you posted when they let me know.
Cheers
Ralph
> Hi Ralph,
Hi Arnel,
That's exactly what you see above. Zeniths haven't been edited only the F2 horizontal angles.
Ralph
> Cheers
> Ralph
HI Ralph,
That is very interesting. That is highly appreciated. 🙂
Thank you.
Cheers,
Arnel
You're welcomed Arnel,
Cheers,
Ralph:-)
