Standard - Long Range Bluetooth Devices Pairing
amdomag
(@amdomag)
Any experience pairing a total station with standard bluetooth with a data collector equipped with long range bluetooth?
Good day!
Thank you.
Posted : July 26, 2013 12:46 am
ps8182
(@ps8182)
500' of range on average. A little more in open flat areas, a little less in wooded areas.
Posted : July 26, 2013 5:14 am
The Pseudo Ranger
(@the-pseudo-ranger)
This came up here a few days ago. According to Wiki, BT comes in 3 classes:
Class 1 - 100 meters
Class 2 - 10 meters
Class 3 - 1 meter
I recall getting about 30 feet out of my Ranger 200/Hiper Pro, so I assume both were equipped with at least Class 2. I suppose one could have been Class 1, but not both.
I'm not sure about long Range BT, those users claim up to 300 meters, so there must be a class better than Class 1. But whatever you have, you'll be limited to your lowest device, so you'll have to see what class your TS and DC are.
Posted : July 26, 2013 6:11 am
amdomag
(@amdomag)
> Class 2 - 10 meters
> Class 3 - 1 meter
You mean the shorter range governs? If my DC has the LRBT with 300m range and my total station BT of 30m range, the effective reach would only be 30m? I hope otherwise.
Posted : July 26, 2013 11:12 am
stephen-ward
(@stephen-ward)
Yes, your distance would be limited by the transmitting range of the weakest device.
Posted : July 26, 2013 11:59 am
amdomag
(@amdomag)
If this is the case then I need to disable my TS BT and employ an external LRBT module and pair it with another LRBT module in DC?
Thanks for sharing. Highly appreciated. 🙂
Posted : July 26, 2013 6:03 pm
