Anyone else in the northeast, noticing reduced rtk capabilities the past 2 weeks?
Working the same site all month & 3 weeks ago could get within 25' if not right up to the treeline no matter the exposure. Past few trips Im flipping to float &/or autonomous at around 75-100' and then have to walk a ways out into the field to lock in again, where before a matter of feet would fix.
Skyview looks good each time with plenty of birds up and spread out. Moved the base to an ideal location, still hasnt improved. Tree cover at horizon is mostly conifer, so I dont feel its the leaf out. Working around it but wondering if its just my unit or anyone experiencing this
I recommend that you follow your manufacturers procedure for clearing the memory on your receivers, and force an almanac update.
Also check that you have the latest firmware update for your receivers.
Will do, thanks guys
