Rightfully So ?
8 Users
(@derek-g-graham-ols-olip)
Another case of unlawful taking
When interpretations decrease the value of a property, then those applying those interpretations need to be assessed that decrease in value.
This appears to be a case where every lot was approved to be buildable, then, as do-gooders decided otherwise, the value of some lots would approach zero. That is not the fault of the land owner. It is the fault of the do-gooder. Surely there are enough intelligent people in the Great State of Misery to get this overturned.
Posted : March 1, 2015 10:49 am
The policies that govern land use (and surveying) are replete with examples of choosing stability over perfection. If I were an affected owner there I would exhaust the administrative processes and head to district court...
Posted : March 1, 2015 12:12 pm
(@mathteacher)
And, on the other side:
http://www.newsobserver.com/2015/02/17/4563473/appellate-court-limits-ncdots.html
Posted : March 1, 2015 5:23 pm
(@brian-allen)
Woo Hoo!! Occasionally the PTB & the "process" will get it right. After all, private property is private property.
Posted : March 1, 2015 7:13 pm
(@mathteacher)
Long process, though, for something that should be obvious to even the most casual observer. One more appeal to go.
Posted : March 2, 2015 7:22 am
(@tommy-young)
Good to see Don Borman is still kicking. He needs to come back and post here.
Posted : March 2, 2015 8:51 am
(@steve-gilbert)
"which would allow measuring the minimum lot width from the actual building line, instead of the setback line."
Are they not the same line?
Posted : March 2, 2015 3:08 pm
(@aliquot)
What is the "actual building line"?
Posted : March 2, 2015 10:05 pm
