Replace Leica CS20 with Allegro MX?
13 Users
(@josh4)
Eminent Member Registered
WIN 20190108 07 41 12 Pro
Josh 4
Posted : 08/01/2019 4:47 am
(@john-putnam)
Noble Member Customer
I have 3 error log files.?ÿ The first has a single line.?ÿ The other 2 what appears to be hundreds of the same error "tC_DevCtrl254 (0x5d1017e)/ 254 ERR phone BasicPhoneRxTxC:: request: writes ('AT+COPS?') returns with 51400709".?ÿ It might have something to do with trying to hit the NTRIP caster without internet service but that is just a guess.?ÿ I would have to delve deeper into it to figure it out.
I'm using V3.02
Posted : 08/01/2019 1:53 pm
(@cameron-watson-pls)
Honorable Member Registered
Here's the folder contents on one of my CS20's.?ÿ
Error Log
Posted : 08/01/2019 2:28 pm
(@jimnj)
New Member Registered
I work for Mike as our Reality Capture Manager. I wanted to thank you guys for taking a look at your CS20's for us. It seems like these error logs are pretty common. I'm going to open up the logs after the next issue we encounter and see if I can find anything relevant on the timestamps of the freeze.?ÿ
I'll report back anything I find in hopes that it may help others down the road.?ÿ
Posted : 09/01/2019 5:05 am
(@andy-j)
On a related note... Can I run current Carlson software on a CS20???ÿ
Posted : 14/08/2019 11:24 am
(@jaccen)
Reputable Member Registered
@andy-j
http://survce.com/supportedHardware
Their page says no.
Posted : 15/08/2019 7:49 am
(@just-a-surveyor)
Famed Member Registered
I can tell you that I had a lot of problems trying to run Carlson Field software on a Leica data collector. It was prone to frequent hangups, failure to communicate, locked screens, and refusal to sync with the robot.?ÿ
Now this was using the Leica Viva software and I realize it has been modified and is a lot better but the Leica dealer told me that their hardware does not work well with another manufacturers software.
The Leica data collector worked flawlessly with Leica software especially if it was using a Leica robot as well.?ÿ
As for Carlson, I've been using it for a couple of decades now and have used it on an Alegre and it worked great.?ÿ
Posted : 15/08/2019 8:38 am
(@loganwoolf)
Active Member Registered
I recommend disabling and not using sleep mode for anything Captivate or Viva. Most connection and crashing issues I face are after an assistant "helps me" by saving battery with sleep mode.
Always disable unused connections.
Avoid button mashing and wait for previous input to complete before starting new input.?ÿ
Hope some of these help.?ÿ
Posted : 22/08/2019 8:40 pm
Share:
