Relying on surveys by others?
11 Users
Many years ago a fellow surveyor with a few decades of business experience made the comment that one should never keep their fees low for a particular client because that would turn out to be the very job/client that will drag you into court or try to get your license taken through no fault of your own. "Ungrateful b******s" was mentioned somewhere in the commentary. Basically, if it's cheap, they assume you cut corners somewhere so they'll come after you to get an even better pay off.
I thought he was terribly pessimistic. Turns out he was a rather astute businessman after all.
Posted : August 29, 2015 7:33 pm
 jph
(@jph)
It's a tough call, what to rely on or how far to go back. But as others have said, you own and are liable for what you show on your plat.
I know of a situation where an un-constructed power line easement was shown incorrectly on a subdivision plat. Then years later another surveyor reconfigured the lot lines, showing the same easement. A house was built on the lot, and later it was discovered that it was in the easement. The second surveyor was sued for the cost of moving the house.
Posted : August 30, 2015 4:33 am
 hack
(@hack)
Jim Frame, post: 334108, member: 10 wrote: This is the one I most heavily rely upon.
Same here Jim. There are surveyors whose boundaries I will accept on the spot and others whose aren't worth the paper they're printed on.
With that said I insist on doing our own title work. We are in Massachusetts which is obviously a m & b state. It's been my experience that when my boundary differs from another surveyor it is usually because the lack of proper research.
Hack
Posted : August 31, 2015 4:17 am
