Real World Example No. 2
18 Users
Brad Foster
(@brad-foster)
"So, is anyone of the opinion that setting a new rod and cap in the hole was improper destruction of important evidence?'
Nope, you could note the evidence with your description:
"Set rod with cap stamped...in found 1/2" diameter hole".
Posted : August 10, 2010 12:25 pm
hpalmer
(@hpalmer)
add a note to your plat: "found and removed a 1/2" hole and replaced with a ..."
Posted : August 10, 2010 2:14 pm
foggyidea
(@foggyidea)
how do you remove a hole? found 1/2" hole filled it with metal
Posted : August 10, 2010 2:20 pm
LOL! It still sounds like removing important "evidence" to me.
Posted : August 10, 2010 3:15 pm
jud
 jud
(@jud)
Found hole at corner, reinforced it with a 1/2" diameter steel rebar. Perpetuating the corner it seems and have removed nothing.
jud
Posted : August 10, 2010 3:57 pm
But ... now there is no hole! You've prevented some future surveyor from ever being able to check the hole. I think it is safe to say that whoever pulled the original rod relied upon the hole and adjusted their ideas about the common boundary accordingly. :>
Posted : August 10, 2010 5:03 pm
squinty-vernier
(@squinty-vernier)
I'm wondering how many holes it takes to fill the Albert Hall.
At 1/2" each, it must be WAY more that 4000.
Rick
Posted : August 11, 2010 4:27 am
Randy Rain
(@randy-rain)
I'd say that this falls under the category of upgrading a substandard monument.
RRain
Posted : August 11, 2010 5:03 am
stacy-carroll
(@stacy-carroll)
Correction: You can check the hole any time you want. Just pull the rod and you'll see that the hole is still there.
Me. "What's the difference?"
Posted : August 11, 2010 7:23 am
DeralOfLawton
(@deral-of-lawton)
Seems like a pretty straight forward rehabilitation so I have no problem with it and in fact have done several of these.
We measure the depth of the hole using wire and then measure the length of wire. I also take a picture of a pencil or something that contrasts from the side showing the hole more clearly.
Deral
Posted : August 11, 2010 8:00 am
