But for your survey to be useful you need to explain why it's a duck. Otherwise it will fall, or require expensive litigation, as soon as someone comes up with an argument for why it isn't a duck.?ÿ
All the evaluation you do to convince yourself is close to useless if you don't communicate your reasoning. A monument doesn't become a corner on a surveyors say so. It becomes a corner when the reasoning the surveyor used is accepted by the world.?ÿ
A key point in convincing the world that an uncalled for monument is the corner is that a thorough search did not find the original.?ÿ
If someone after you finds the original, there may be an argument for holding your corner, but you didn't make that argument, and your survey was not complete.?ÿ
Posted : August 11, 2021 10:40 am
