Puzzling Carlson issue
2 Users
just-a-surveyor
(@just-a-surveyor)
When I go to my File Pulldown menu and select PDF the Output Layouts to PDF it produces a PDF that is mirrored and flipped from the drawing.
Any clue why it would do a thing like that?
EDIT: I should note that the standard EXPORT to PDF works but the other method is screwy.
Posted : November 6, 2017 4:48 pm
stephen-ward
(@stephen-ward)
Just A. Surveyor, post: 454263, member: 12855 wrote: When I go to my File Pulldown menu and select PDF the Output Layouts to PDF it produces a PDF that is mirrored and flipped from the drawing.
There's a setting in there that tells it to "Use Layout Settings", I'd try un-checking that box just to see if you get different results.
Posted : November 6, 2017 4:57 pm
