Problem with Topcon Hiper Lite +
5 Users
(@mike-lacey)
My computer stopped recognizing my base when I hook it up using the usb cable. No problem with it recognizing the rover, and the PCCDU software works with the rover, so I don't think it is a driver or cable issue. I tried it both on my desktop and laptop. I did a reset on the base, and that did not help. Anybody have any ideas?
Posted : July 26, 2013 6:12 am
(@david-livingstone)
We had a set of the regular Hipers for about 10 years. I seem to recall that we had problems with almost all of the ports at one time or another. I would guess its a bad port. Do you use this as an RTK setup? If you do, hook up a data collector to that port and see if it works.
Posted : July 26, 2013 7:01 am
(@j-t-strickland)
I had a port go bad, also, had it replaced.
My other com and usb port worked, though.
Posted : July 26, 2013 9:16 am
(@jeffe)
Just two weeks ago, I thought that I had 'fried' my Hiper Lites by plugging the charger into the USB port. I could not get the units to give me any fixes, although I could talk to them via the dc by blue tooth. Could not communicate via USB to either one. I was so convinced that I sent them off to my dealer to check out.
He connected to them via the serial port, confirmed the USB ports were bad and said it wouldn't be economical to fix them. He told me that in the last 7-9 years he hardly ever heard of a USB port on the Hipers going bad, but in the last year they have 8-9 just quit working. So it seems that mine quit working (base & rover) at the same time!
I was never quite so happy to get bad news (that the USB ports were bad) but I hadn't actually killed the Hipers, although I had myself thoroughly convinced I had done them in. He updated the firmware, turned on Cinderella for me, charged me fairly.
Short story, use serial, get a usb/serial converter, at least now you have more cable to play with.
Jeff
Posted : July 26, 2013 4:32 pm
(@mike-lacey)
Sounds like I got a bad port.
Thanks for your responses.
Posted : July 27, 2013 3:55 am
(@denny)
I have a Hiper SR. Similar problem. Have receiver, no help, have to vent
started with one xp machine lost serial port access switched to usb
worked for awhile. Started a serial connection on another machine worked fine
for awhile. then started a usb connection on another xp machine
one night I worked for close to an hour before I could connect
went to machine number 2 for serial connect got multiple different
error messages but when I connect to machine 3 all is well
and this is JUST A SHORTED DESCRIPTION OF THE PROBLEMS WHIT THESE
STATE OF THE ART MACHINE
BTW I also tried a windows 7 machine an gave up in disgust with that exercise
in futility sometime they wory and sometimes they do not I think its a poorly
written driver I could go on for hours about connection problems
no help from vender. This is only a "very" brief description of problem
as Chevy Chase said pass the tylonal
Posted : July 29, 2013 4:18 am
(@denny)
Follow up 2 static files from yesterday
Hiper connects to Pc Usb one file keeps kicking out
other is downloaded
Friday was ok for one file
Never had anything so frustrating as these
State of the art contraptions
Posted : July 30, 2013 5:37 am
(@denny)
Follow up switched to computer 2
Serial get a data invalid message
usually when I get this I go to
computer 3 usb and everything is ok
Today not so lucky maybe in 10 minutes or so
Last week took several hours
These things have cost me countless
no productive hours for several reasons
will not ever do again had a 802ar that
I did not like either
Posted : July 30, 2013 5:54 am
(@denny)
Just got it to download on computer no 3 USB
This goes on every time no better luck with other
Hiper either
Posted : July 30, 2013 5:58 am
(@denny)
BTW I have used Ashtech receivers for 12-14 years and never
had problems like this.
NEVER
Posted : July 30, 2013 6:08 am
