I have an upcoming survey to do in a subdivision that was done in 1952. It was common practice in many of these older subdivisions to place all of the excess and deficiency in the last lot on the block, typified by a dimension with a +/- after it (See example below). This promises to be a fun little job for me because all of the original corners were 'scribed spruce stakes'. I've actually recovered a few in neighboring subdivisions done around the same time by the same surveyor, but time has not treated them well. I've also noticed that a good many of the corners reset over the years here have been prorated in. In other words the excess and deficiency has been equally divided (supposedly) amongst all of the lots equally. I was taught that in this type of situation, that would not be the correct approach as all of the excess or deficiency should go in that last lot with the +/- dimension, unless the original corners show to the contrary. I haven't had to deal with one of these in some time so I wanted to see if there was any agreement that this would be the correct approach under the circumstances. It's my hope to recover the original stakes which should be still intact below ground. Call me an optimist. 😉
Thank you in advance.
Willy
I think Brown’s Boundary Control and Legal Principles has some excellent info on this. I don’t remember if it deals with this specifically but I was always taught that the excess and deficiency was put in the last lot if the dimension was not included on the plat. As far as your situation I think it could go a couple different ways, since the distance is down to the tenth and the rest are to the foot than you could reason that excess and deficiency be applied to the last lot only if it does not change the foot distance. Any more like feet could reasonably be distributed between all lots. This should be last resort. The best bet would be that you do find some other evidence so that you do not have to do the entire block.
I also think that your way of applying it could fly as there is a plus minus on distance and it could be argued intent was for all error in this lot.
Good luck finding some evidence.
Thanks Bear Bait. Brown's is my go to but doesn't seem to address this particular set of circumstances with the +/- in the last lot on the block. I told the people that hired me that if they couldn't budget enough time for me to do it right I wouldn't be interested and I needed to do it before freeze up for obvious reasons. I should be able to narrow down the search to +/- a foot and scrape away the duff down to mineral soil and with luck, voila! No proration needed and I'm bullet proof. 🙂
Is it clear from the records that the subdivision was platted in the office from prior surveys by others? If that is so, the purpose of the +/- dimensions would be plain enough, i.e. to lay out regular lots of a fixed frontage and let the +/- be whatever was left. It's hard to imagine the lots being laid out on the ground before the plat was prepared because the +/- dimension would presumably have been measured in the course of the work and so would not be expressed as a "more or less" figure unless there was some uncertainty in the location of the West line of the tract subdivided that isn't otherwise apparent.
I doubt plats of that age typically intended to express significant figures. The 323 could be read as if it was 323.0 to the same precision as any other measurement on the plat, and certainly not as 323 +/- 0.5 ft.
Side question, why is it -/+ when +/- is much more common?
Before worrying about a tenth or two proportioning the lot corners, [sarcasm]you'd better go to the 1/4 & section corners and re-subdivide that sucker to be sure the GLO was precise enough on their section subdivision. As we all know, those interior 16th corners need to be within an acceptable "circle of error" to be correct.[/sarcasm]
> Before worrying about a tenth or two proportioning the lot corners, you'd better go to the 1/4 & section corners and re-subdivide that sucker to be sure the GLO was precise enough on their section subdivision. As we all know, those interior 16th corners need to be within an acceptable "circle of error" to be correct.
Actually, as I understand the portion of the plat that was posted, the corners shown as controlling the boundaries of the tract subdivided are specific monuments placed at specific times, not generic PLSS corners. So, the exercise is figuring out where those corners were monumented by the GLO on the ground at the time that the subdivision was platted and/or the lots staked.
You do understand what the [sarcasm]sarcasm font[/sarcasm] is typically used for, don't you?
> You do understand what the sarcasm font is typically used for, don't you?
Yes, it's something you edit out when quoting what another poster has written since the sarcasm font is for sissies, generally. :>
Well, the dimension it appears beside is significantly less than that of the regular lots. So the emphasis is on the LESS aspect of the tolerance, not the MORE.
You mentioned other surveyors had proportioned. It would be a jump for me if I was doing this to throw the slop in the last lots. In Alaska, there are plenty of old paper plats that were computed in the winter (I always thought one up there being Williwaw Subdivision in Wasilla, which is ironic to your handle on this site) I would think the intent was to show there might be some uncertainty on his precision to the subdivisional line. Here's to finding some evidence along one of these lines..it will help you solve it.
"scribed spruce stake" from 1952?
WOW! Down here pine lath fall over after about 6 weeks. Nothing left below ground line.
But I suppose the alternative is frost heaving iron pins out of the ground. Well, that and working year round.;-)
Completely up to the state regs. Here in PA, it all goes into the last lot sold from the original property, except in towns where it is prorated out.
The thinking behind it is that out of 110', person one bought 40', person 2 bought 40', and person 3 just thought they bought 40', but the landowner didn't have 40' to sell, so they bought 30'
This logic does not go over very well when the properties were sold 150 years ago, and everyone has just been using about 36' + or -, with the third owner suddenly having half their house off the property. I generally try to convince them to just let me document what they are using and get lot line adjustments for everyone.
The "more or less" calls are just the beginning of your quest. Wait til the neighbors come out and start with their "what's going on?" and their "is everything wrong" stuff. :excruciating:
It sounds like you are describing sequential creation of parcels. Do they treat plats as sequential creations in PA?
