Opus reject
7 Users
(@warrenward)
I sent a .dat file to OPUS and it rejected, with a message that "OPUS can't convert this file to Rinex".
This was over 4 hours of log, and I usually have no problem, followed the same procedure. Is it possible that something wrong happened to my dat file while logging, that I don't know about?
thanks
ww CO PLS
- Have a nice day! Or, may your monument prevail over some guy's touchscreen.
Posted : April 21, 2014 6:27 am
(@lee-d)
I would make sure I have the latest version of RINEX Conversion, convert the T01 (or T02) file, and submit the o14 file.
Posted : April 21, 2014 6:43 am
(@drilldo)
Download the free rinex utility and convert it yourself then submit.
Posted : April 21, 2014 7:19 am
(@steve-corley)
TEQC Front End
Downlaod Mark Huber's front end for TEQC at http://teqc.silkwerks.com/ and use it to convert and check your file. There are instructions and tutorials on the site that explain how to use it.:-)
Posted : April 21, 2014 7:34 am
I usually (mostly) convert trimble dat files to RINEX and then submit. The command for converting a dat file to rinex using teqc is simple:
teqc -tr d xxxx1000.dat>xxxx100.14o for day 100.
Actually, it will usually work without the "-tr d" parameters, since I believe it assumes trimble download format by default for a .dat file. But, it doesn't hurt to include them.
teqc does many other things (and it is free). Very much worth spending some time to get familiar with it.
Posted : April 21, 2014 9:27 am
(@kris-morgan)
OPUS has not taken native format (Trimble) files for quite some time, at least on my end. I've had to convert to rinex for 8 years or so now.
Posted : April 21, 2014 11:48 am
(@warrenward)
thanks for all the information. what really confuses me is that I have not had any problem getting OPUS solutions, until this file got rejected. I don't send in every day, but about once a week for years.
Posted : April 21, 2014 5:19 pm
Warren
Send me the .DAT file, and I'll try and take a look at it tonight.
LDOGEO at aol dot com
use lower case LDOGEO
Loysl
Posted : April 21, 2014 6:00 pm
