Odd NGS data sheet problem
John1Minor2
(@john1minor2)
I'm having trouble with PID OA0630 sta. S 751 from the NGS website. It will only download about the first 15 lines then quits. Doesn't matter if I search by PID or Sta Name. The problem is unique to my computer because others I have asked have been able to download it. I am able to download other stations in their entirety. The problem is just with this one station. I have a copy of the data from previous work. I intend to occupy this station this Saturday as part of the NSPS effort.
Any ideas on what the download problem might be? Something to do with cookies? I don't have a clue.
Posted : March 16, 2011 4:56 pm
John1Minor2
(@john1minor2)
Well it doesn't appear to be cookies or a registry problem. I ran CCleaner and the problem is still there.
Posted : March 16, 2011 5:15 pm
No problem for me. Maybe it is related to the browser are you using?
I never have problems downloading them to the browser or saving them as text files. I do have a problem that I think is in my printer driver that will sometimes refuse to print the whole sheet. If I edit out some of the lines it will probably work, but I haven't nailed down exactly what-I'm suspecting the full width underlines but that isn't where it stops printing.
DATABASE = ,PROGRAM = datasheet, VERSION = 7.85
1 National Geodetic Survey, Retrieval Date = MARCH 16, 2011
OA0630 ***********************************************************************
OA0630 DESIGNATION - S 751
OA0630 PID - OA0630
OA0630 STATE/COUNTY- OR/COOS
OA0630 USGS QUAD - NORTH BEND (1971)
OA0630
OA0630 *CURRENT SURVEY CONTROL
OA0630 ___________________________________________________________________
OA0630* NAD 83(1986)- 43 23 29. (N) 124 14 42. (W) SCALED
OA0630* NAVD 88 - 37.421 (meters) 122.77 (feet) ADJUSTED
OA0630 GEOID HEIGHT- -25.83 (meters) GEOID09
OA0630 DYNAMIC HT - 37.416 (meters) 122.76 (feet) COMP
OA0630 MODELED GRAV- 980,471.8 (mgal) NAVD 88
OA0630
OA0630 VERT ORDER - FIRST CLASS II
OA0630
OA0630.The horizontal coordinates were scaled from a topographic map and have
OA0630.an estimated accuracy of +/- 6 seconds.
OA0630
OA0630.The orthometric height was determined by differential leveling and
OA0630.adjusted in June 1991.
OA0630
OA0630.The geoid height was determined by GEOID09.
OA0630
OA0630.The dynamic height is computed by dividing the NAVD 88
OA0630.geopotential number by the normal gravity value computed on the
OA0630.Geodetic Reference System of 1980 (GRS 80) ellipsoid at 45
OA0630.degrees latitude (g = 980.6199 gals.).
OA0630
OA0630.The modeled gravity was interpolated from observed gravity values.
OA0630
OA0630; North East Units Estimated Accuracy
OA0630;SPC OR S - 198,370. 1,196,710. MT (+/- 180 meters Scaled)
OA0630
OA0630 SUPERSEDED SURVEY CONTROL
OA0630
OA0630.No superseded survey control is available for this station.
OA0630
OA0630_U.S. NATIONAL GRID SPATIAL ADDRESS: 10TCP991050(NAD 83)
OA0630_MARKER: I = METAL ROD
OA0630_SETTING: 49 = STAINLESS STEEL ROD W/O SLEEVE (10 FT.+)
OA0630_SP_SET: STAINLESS STEEL ROD
OA0630_STAMPING: S 751 1987
OA0630_MARK LOGO: NGS
OA0630_PROJECTION: FLUSH
OA0630_STABILITY: B = PROBABLY HOLD POSITION/ELEVATION WELL
OA0630_SATELLITE: THE SITE LOCATION WAS REPORTED AS SUITABLE FOR
OA0630+SATELLITE: SATELLITE OBSERVATIONS - October 06, 2006
OA0630_ROD/PIPE-DEPTH: 13.4 meters
OA0630
OA0630 HISTORY - Date Condition Report By
OA0630 HISTORY - 1987 MONUMENTED NGS
OA0630 HISTORY - 19940629 GOOD USPSQD
OA0630 HISTORY - 20000205 GOOD USPSQD
OA0630 HISTORY - 20010929 GOOD USPSQD
OA0630 HISTORY - 20061006 GOOD USPSQD
OA0630
OA0630 STATION DESCRIPTION
OA0630
OA0630'DESCRIBED BY NATIONAL GEODETIC SURVEY 1987
OA0630'IN NORTH BEND.
OA0630'IN NORTH BEND, AT THE INTERSECTION OF NEWMARK AVENUE AND ASH STREET,
OA0630'9.1 M (29.9 FT) EAST-NORTHEAST OF THE NORTHEAST CORNER OF THE ASH
OA0630'PUMP STATION, 8.8 M (28.9 FT) SOUTH OF THE CENTERLINE OF THE
OA0630'EASTBOUND LANES OF THE AVENUE, 7.5 M (24.6 FT) WEST OF THE CENTER OF
OA0630'THE STREET, 0.9 M (3.0 FT) NORTH OF UTILITY POLE NUMBER 217701, AND
OA0630'0.7 M (2.3 FT) WEST OF THE WEST EDGE OF SIDEWALK. NOTE--ACCESS TO
OA0630'DATUM POINT IS HAD THROUGH A 5-INCH LOGO CAP.
OA0630'THE MARK IS ABOVE LEVEL WITH SIDEWALK.
OA0630
OA0630 STATION RECOVERY (1994)
OA0630
OA0630'RECOVERY NOTE BY US POWER SQUADRON 1994
OA0630'RECOVERED IN GOOD CONDITION.
OA0630
OA0630 STATION RECOVERY (2000)
OA0630
OA0630'RECOVERY NOTE BY US POWER SQUADRON 2000
OA0630
OA0630 STATION RECOVERY (2001)
OA0630
OA0630'RECOVERY NOTE BY US POWER SQUADRON 2001 (AES)
OA0630
OA0630 STATION RECOVERY (2006)
OA0630
OA0630'RECOVERY NOTE BY US POWER SQUADRON 2006 (SO)
*** retrieval complete.
Elapsed Time = 00:00:01
Posted : March 16, 2011 5:17 pm
You might also try fixing the nut on the keyboard 😉
Sorry I couldn't be more help:-) Sometimes turning something off and turning it back on again does the trick.
Good Luck!
Radar
Posted : March 16, 2011 5:19 pm
John1Minor2
(@john1minor2)
Thanks Bill and Radar
I have rebooted several times to no avail. Really weird problem. Hope it doesn't spread to other datasheets.
Posted : March 16, 2011 5:26 pm
This is a download accessory program that has helped me in the past. If the download is interrupted, it will start where it ended on the next attempt.
GetRight
The problem I've had in the past was a problem with my memory allocation and the timing dialogue of my server. This program helped until my server improved its act.
Posted : March 16, 2011 6:08 pm
John1Minor2
(@john1minor2)
Thanks A Harris
I downloaded GETRIGHT but still only get about the first 15 lines of the data sheet.
Posted : March 16, 2011 6:29 pm
