No GPS Satellites Available
5 Users
field-dog
(@field-dog)
Only GLONASS satellites available right now. Anyone else having this problem?
Posted : April 8, 2019 11:43 am
What receiver model and firmware version??ÿ It may well be due to the GPS week number rollover, which has affected some firmware/software but not most. There are lots of threads about it on the forum, so you should look for information about your hardware to see what its situation is.
My antique Trimble 4000sse is receiving a bunch of GPS satellites inside the house right now.?ÿ I expect to continue needing to specify the week number myself when using TEQC to convert to RINEX.
Posted : April 8, 2019 12:02 pm
field-dog
(@field-dog)
Topcon HiPer SR. The firmware was updated in February. I don't know the version. I forgot about the roller. I'll take your advice and search the forum. Thanks, Bill!
Posted : April 8, 2019 5:03 pm
field-dog
(@field-dog)
Firmware version 4.7 HSR Mar, 07, 2018 p8
Posted : April 10, 2019 11:29 am
MitchPTD
(@mitchptd)
Reset the NVram/ Factory Reset.?ÿ Worked for me earlier today, was only tracking 4 glonass.?ÿ I just did it in Magnet Field, never used the Minter Panel and it works.
Posted : April 10, 2019 1:07 pm
field-dog
(@field-dog)
From Terminus-NC April 10, 2019 9:08 am:
We just uploaded all our FC-5000 data collectors to the latest version of Magnet. We used the clear NVRAM pretty often in the past and cannot seem to find the routine in the new version. We do see the Factory Reset option, but does anybody now what happened to the clear the ram routine?
Hope I have better luck! What's the Minter Panel? I was tracking 7 GLONASS satellites this afternoon.
Posted : April 10, 2019 3:22 pm
MitchPTD
(@mitchptd)
That is the same as a resetting the NVram.  Yes.
Posted : April 11, 2019 7:16 am
AZLS
 AZLS
(@azls)
This happened to us for the last 3 days. Doing a Factory reset help for a little while, then went back to the problem. Finally got all the units to take the new firmware update last night, this morning everything fired up and worked with no issues. It is 100% firmware issue, you need to updated yours.
Posted : April 11, 2019 8:56 am
larry-scott
(@larry-scott)
Posted by: Field Dog
That is most likely the old ephemeris is the receiverƒ??s memory post rollover. So if thereƒ??s a memory reset (not a factory default reset) to dump eph thatƒ??s the ticket. Factory reset works too, but I found it unnecessary. Ephemeris is week number based.?ÿ
Posted : April 14, 2019 8:31 am
