NASA Surveyors Wanted
12 Users
seb
 seb
(@seb)
http://mars.nasa.gov/multimedia/resources/mars-posters-explorers-wanted/?linkId=25534067
Posted : June 29, 2016 5:29 pm
Seb, post: 379479, member: 7509 wrote: http://mars.nasa.gov/multimedia/resources/mars-posters-explorers-wanted/?linkId=25534067
So, is this just a request for a quote? I'll bet if NASA calls around they will be able to find a surveying firm that can produce surveys of Mars right from the Houston office and it shouldn't cost any more than any other survey.
Posted : June 29, 2016 5:48 pm
seb
 seb
(@seb)
Now that you mention it.....
http://www.theverge.com/tldr/2016/3/1/11140786/mars-hand-drawn-map-eleanor-lutz
Posted : June 29, 2016 5:55 pm
Seb, post: 379484, member: 7509 wrote: Now that you mention it.....
Okay, but I'll bet the UPDATE and RECERTIFICATION will cost you at least three hundred.
Posted : June 29, 2016 6:35 pm
Is Mars a recording planet?
Posted : June 29, 2016 7:12 pm
FrancisH
(@francish)
I hate to see the Mobilization Cost of the quote.
Posted : June 29, 2016 7:32 pm
toivo1037
(@toivo1037)
Do you hold the original position of the rovers, or do you restake them in the intended position?
Posted : June 29, 2016 7:53 pm
C Billingsley
(@c-billingsley)
No atmospheric correction to worry about
Posted : June 29, 2016 8:06 pm
Kent McMillan, post: 379488, member: 3 wrote: Okay, but I'll bet the UPDATE and RECERTIFICATION will cost you at least three hundred.
All Points Precision Surveying would like to bid $200 for a cloth tape survey off the fences.
Posted : June 29, 2016 9:50 pm
I believe the wait time for utility locates is REALLY a long time up there....
Posted : June 29, 2016 10:07 pm
john-nolton
(@john-nolton)
C Billingsley, post: 379499, member: 1965 wrote: No atmospheric correction to worry about
Of course there would be a atmospheric correction.
Mars has approx. 96 % carbon dioxide, 1.9 % argon, 1.9 % nitrogen, 0.146 % oxygen, o.o557 % carbon monoxide (plus a trace of several other gases).
Temperature on Mars: it can reach 70 F at the equator and minus 100 at night. Pressure; average of 6 mbar. The correction formula that you use for your specific EDMI on Earth would not work on Mars
Earth has approx. 78 % nitrogen, 20.95 % oxygen, 0.93 % argon and 0.039& carbon dioxide. You know the temp. and pressure here on Earth as you
take it each time you make a EDMI measurement, wet and dry bulb readings if you do geodetic work.
You would need to put the gases of Mars in a special interferometer and determine a correction formula to use.
JOHN NOLTON
Posted : June 29, 2016 10:20 pm
But the total air pressure on Mars is so small, about 0.6% of Earth's mean sea level pressure, that the correction would be negligible for most purposes. It's nearly a vacuum.
https://en.wikipedia.org/wiki/Atmosphere_of_Mars
Posted : June 30, 2016 9:01 am
I should have said the temperature correction would be negligible. With almost no pressure, the basic speed of light would apply rather than the nominal speed in atmostphere that earth instruments are built to use as "0 ppm".
Posted : June 30, 2016 9:20 am
Does anyone know who sits on the Mars Board of Licensure? I have some really stupid questions to ask...
Posted : June 30, 2016 9:58 am
thebionicman, post: 379564, member: 8136 wrote: Does anyone know who sits on the Mars Board of Licensure? I have some really stupid questions to ask...
Posted : June 30, 2016 10:09 am
Andy Nold
(@andy-nold)
I still haven't gotten approval on my comity application. Their office never seems to answer the phone either.
Posted : June 30, 2016 2:12 pm
