Ok guys,
Need help linking Topcon machine control to my Sokkia GRX1 Base. Is it possible to pair these?
Thanks,
If the radio frequency are compatible, then yes you can.
leegreen, post: 438174, member: 2332 wrote: If the radio frequency are compatible, then yes you can.
My Sokkia is uhf 463 MHz/12500hz but I don't know which option to choose on the topcon configure radio screen
You have not provide enough information for us to help you. We don't know what Topcon machine control system your are using. We don't know any of the hardware type or settings. Your Sokkia GRX1 has a UHF radio, if the Machine Control system also has a UHF, then you need to match the Frequency, Protocol, Channel Spacing etc.
Why not ask your dealer or whom you purchased it from?
leegreen, post: 438252, member: 2332 wrote: You have not provide enough information for us to help you. We don't know what Topcon machine control system your are using. We don't know any of the hardware type or settings. Your Sokkia GRX1 has a UHF radio, if the Machine Control system also has a UHF, then you need to match the Frequency, Protocol, Channel Spacing etc.
It's a demo dozer until I get mine out of the shop. I run Leicca on my dozers and this is a 750 John Deere smart grade with integrated topcon 3DMC2. The dealer doesn't seem very up to speed on the system yet either
Give me a call 315 831-8175
