Hi all, Just started using a cs20 with a TS15
I can connect via bluetooth to the RH16 Handle but i nly get about 30 odd meters before it drops out
I reconnected and made sure I was connected to the RH and not the Instrument itself but it is connecting to the bluetooth.
Is there anything I may be doing wrong or should i be connecthing the Long Range TPS to the TS and not the RH
any advice appreciated?ÿ
Thanks in adveance!
Brendan
Long range bluetooth to radio handle is correct. Connecting to the instrument direct will probably drop out after a few metres.
The range is very variable on the LRBT, especially if there is anything in line of sight between the controller and instrument.
There is a CTR20 expansion module for longer range communications I would be interested to know more about.
