Leica tribrach
Pinetree
(@pinetree)
Can anyone tell me where the adjustment screws are on this Leica tribrach? I don't know the model number because the sticker is worn out.
Posted : May 15, 2014 3:13 pm
stephen-ward
(@stephen-ward)
Under the bubble?
Posted : May 15, 2014 3:30 pm
Pinetree
(@pinetree)
I should have specified that it is the optical plummet I am trying to adjust - not the bubble.
Posted : May 15, 2014 3:37 pm
There should be two adjustment screws on the right side of the sight tube and on the side of the flat assembly and just under the top plate.
Posted : May 15, 2014 4:18 pm
Pinetree
(@pinetree)
I see the two on the right side but I don't see the other one.
Posted : May 15, 2014 5:16 pm
Those two are the only adjustments to the crosshair adjustment
turn right & turn left
Posted : May 15, 2014 6:26 pm
cwlawley
(@cwlawley)
Loosen the large flathead screw the right a bit. Adjust the two smaller flathead screws the left. The crosshairs will move in an X pattern. Retighten the right screw when perfect.
Posted : May 15, 2014 9:41 pm
Pinetree
(@pinetree)
Ok, got it. Thanks to all of you.
Posted : May 16, 2014 7:05 am
