Leica TCRP 1205+ radio
FLS
 FLS
(@fls)
What is the best radio setting between a TCRP 1205+ and an Allegro MX?
Thank you
Posted : January 11, 2016 7:32 am
Not sure what you mean by "setting," but long-range Bluetooth (e.g. Parani SD1000) works well at both ends.
Posted : January 11, 2016 8:33 am
FLS
 FLS
(@fls)
This unit isn't long range Bluetooth, it is using the radio handle. Trying to find the correct listed radio for this combo. The one we are using has to constantly connect and it keeps on showing the baud rates etc.
Posted : January 11, 2016 5:47 pm
The http://www.junipersys.com/content/download/8187/107926/version/1/file/%22/Leica-Radio-Modem-Troubleshooting.pdf%22&apos ;">Leica Radio Modem Troubleshooting paper from Juniper Systems (makers of the Allegro) might be useful.
Posted : January 11, 2016 6:07 pm
cwlawley
(@cwlawley)
Assuming that you are using Carlson on the Data Collector...
Choose "Leica Remote Control" under the Comms Tab, Port 3, Baud Rate 19200.
You may need to install RMTool, you can get this from the Knowledge Base on Carlson's website to program the internal radio on the Allegro. You will install, then connect using Port 3, TPS1200 to RH1200 Radiohandle.
Make sure these settings match the settings in the instrument.
Posted : January 11, 2016 7:23 pm
FLS
 FLS
(@fls)
Thank you
Posted : January 12, 2016 8:03 am
