Any idea of the price difference between the two models? Which model do you prefer?
Happy Easter everyone..
Thank you..
Depends on what you're using it for. TS50 is a monitoring station (0.5") where as the TS15 is a 1". I think the EDM on the TS50 is calibrated to a higher precision as well if I recall correctly...?
I think it is the TM50 for monitoring works. To my knowledge, the TS50 is for high precision measuring tasks. It's angular accuracy is 0.5" better than the 1" TS15P. RL range is same at 1,000m.
I would think that the TS50 is an overkill for land surveyors. If the price difference is considerably low then TS50 is I think the better choice.
Anyone has the idea of price difference?
Thank you guys!
The prices change per country. You have to ask your local dealer. However, if i was in your position i'd compare an MS50 VS TS15I. B-)
