Leica CS20 TS Compatability
Jhwfoat
(@jhwfoat)
We recently upgraded to a CS20 collector running captivate for our GNSS. Works great. Now our two very outdated topcon total stations are deciding they have had enough and we are looking at getting a total station or robot within a reasonable price range. I'm just having a hard time finding information on what would make a gun compatible with the CS20? We are trying to stay in a decent price range?ÿ so looking at older models of guns but just stuck on which ones would work with our CS20 collector.
Posted : October 24, 2022 7:40 am
john-putnam
(@john-putnam)
Supporter
The current release of Captivate is v7.03 (at least as of last week).?ÿ You should be able to run any Leica TS running Viva/Smartworks v9.x.?ÿ I use mine with my mainline instrument, a MS50, as well as a backup TCRP1201 with no problems.?ÿ I don't know much about other brands but there is a list of them in Captivates TS connection wizard.
Posted : October 26, 2022 8:45 am
bobwesterman
(@bobwesterman)
Posted by: @jhwfoat
Look at the settings page in captivate and see what ts or robots are listed there.
Posted : October 26, 2022 9:29 am
Jhwfoat
(@jhwfoat)
I don't have a TS connection wizard under my settings/connections... Bear with me just started using the cs20 a few months ago and only have it hooked up for a GS..
Posted : October 26, 2022 9:59 am
Jhwfoat
(@jhwfoat)
Had it seet on GS only.. Found the connection wizard... Only a few TS even under leica are listed. It doesn't even have the TCRP's in the list.
Posted : October 26, 2022 10:13 am
summerprophet
(@summerprophet)
While there is no reference in the manual, or online guidance, it IS possible to connect via cable to older Leica total stations.?ÿ
I successfully connected to a Leica TCR703, and everything worked as expected including changing from prism to reflectorless Uncertain if you could get it to work with non-Leica products or if you could even get the correct cable for such a connection.?ÿ
From memory, I just selected the oldest type of Leica TS listed, and modified the parity and baud rate to match the total station.
Posted : October 26, 2022 7:27 pm
