Leica Captivate on Leica CS20 - Exporting Design Elevation and a Spot Elevation from a DTM
DaveJay
(@davejay)
Hi All,
I'm using a Leica CS20 controller and I have a DTM in the form of a DXF installed. I can use the Stake to DTM function and take as-built shots and see the difference between the as-built shot and the design elevation at that location. My issue is that when I try to export the data I can't seem to include the design elevation with each spot elevation. I've tried Exporting Data, ASCII,?ÿ with my settings at Point ID, Northing, Easting, and Height. Then I've filled in the rest of the positions with Code, Code Description, and Attribute 1, 2, 3, etc., but I still cannot seem to get the design elevation. I've also tried Exporting ASCII with format file and used a format file with (P,N,E, D,O) with similar results.
Any advice would be greatly appreciated.
Dave
Posted : October 28, 2019 11:01 am
least
(@least)
I think you will need to make a custom format file, using LGO format manager.
The Log file | stakeout | staked points has options to include design point info, along with stakeout difference etc.
Posted : October 28, 2019 11:26 am
DaveJay
(@davejay)
My second attempt was with a custom format file created in LGO, using P,N,E,D,O. I didn't have any luck with that either.
Thanks,
Posted : October 28, 2019 12:52 pm
Eric Kara
(@eric-kara)
In DTM Stake out:
  1. Press FN than F6 for "Tools"
  2. Select "Export Cut Sheet"
  3. Select Cut Sheet Definition
    1. Select F2 "New"
    2. Name your cut sheet, choose your delimiter and then "contents" for your?ÿ
Let me know if you have any problems.?ÿ
Posted : October 28, 2019 1:52 pm
