Laser for Inverts
14 Users
@ct thanks, I am curious about workflow inside the manhole.
Posted : September 14, 2021 7:09 am
(@oldpacer)
There are several Disto models. I am sure you can find one that fits your price/function needs. Correcting the measurement to a vertical distance, value checking and a strong laser are items you need. I have stopped verifying my measurements each time and am confident the value is want I expected. Make sure you can see the dot, through the water, on the bottom of the pipe invert. Shoot several, some at higher places and verify that your readings indicate the same.?ÿ A mid-range Disto will also shoot through screen, and will shoot through glass if you hold the Disto directly and square against the pane.?ÿ
And my reply to comments yet to come, "I collect enough improvement measurements to verify my eccentric shots are correct."?ÿ
Posted : September 14, 2021 7:24 am
(@hi-staker)
@ct We have one of these and use it to measure to bearing trees when we are doing corner accessories during boundary ties. Works fantastic on steep slopes and has really sped up the time we spend at each corner.
Posted : September 14, 2021 7:32 am
(@dmyhill)
@martin_au?ÿ
why do you want to be in the center of the manhole LID?
Do you not shoot the center of the actual manhole (which is typically at the edge of a lid)?
Do you shoot both??ÿ
Posted : September 14, 2021 7:33 am
(@dmyhill)
@norman-oklahoma?ÿ
and when it gets dropped in the manhole...$100 feels a lot better than $1000
Posted : September 14, 2021 7:34 am
E0313875 4B7B 4E01 A2F2 A94CDE1E9FDA
I think I found what I was looking for from the specs link @ct shared.
Take indirect height and width measurements using the Pythagorean Theorem. The key is to make sure your second shot -- the "rectangular shot" -- is perpendicular to the point you are measuring, shown as the 90?ø angle in the images. The best way to ensure accuracy is to use a tripod and an adapter.
~ or maybe this tlit sensor reference ~
Posted : September 14, 2021 7:48 am
(@martin_au)
@brad-ott?ÿ
You're after the tilt sensor specification. Means it can calc all the distances based on the slope distance and tilt value.
Only thing to watch for it so check it's a full 360?§ tilt. Some are only ?ñ45?§, which are a bit of a fail for inverts.
Posted : September 15, 2021 4:18 am
@martin_au thanks a million, friend. ?ÿOrdered mine yesterday. ?ÿLooking forward to keeping my invert measure down notes nice and neat via the Bluetooth synched Leica Disto App on my iPhone too.
Posted : September 15, 2021 4:58 am
4ACA9DA2 479F 4DF6 89C5 E98D959BEE09
I am very encouraged by the ease of use and quick learning curve getting to know the app even before I have the device. ?ÿImagine these two coffee cups are manholes out on site somewhere.
Posted : September 15, 2021 5:27 am
(@hi-staker)
@brad-ott Does @holy cow know you stole his coffee cup?
Posted : September 15, 2021 8:52 am
(@richard-imrie)
@brad-ott?ÿ
I'm going ring ring that number on the other mug and ask for a price for one corner.
Posted : September 15, 2021 11:25 am
(@dave-o)
@norman-oklahoma And you don't have to wipe off the Bosch too often either.
Posted : September 15, 2021 11:31 am
I am very happy with my purchase!?ÿ Thanks @ct.
They should call this Smart HV mode:
A
550
360
B
Posted : September 16, 2021 1:22 pm
Posted by: @ct
It measures the angle and slope and reports the calculated vertical.
Correct. ?ÿIt does. ?ÿWell stated. ?ÿI just did not believe you before. ?ÿI do now.
Posted : September 16, 2021 1:33 pm
 CT
(@ct)
Posted by: @brad-ott
Not sure how to take that comment ???? Enjoy!
Posted : September 16, 2021 1:42 pm
