Javad Triumph & Rapid-Static
corey-f
(@corey-f)
I have not had any success getting opus to accept a rapid-static session (usually about 45-60 min worth of data). If I run 2+ hours and submit through opus static, everything works great. I'm not sure if there is something I am doing wrong, or if there are others with the same issue. Any suggestions from fellow triumph users?
Corey
Posted : July 31, 2013 7:20 pm
OPUS-RS requires L1, C1/P1, L2 and P2 observations, that are clean. Create a RINEX file and open in WordPad or some other text editor. Take a look at the data, if the C1/P1 and/or P2 are not there and clean at the first few epochs OPUS-RS looks no farther into your file. If the data is stored too soon after turning the unit on this happens. Edit out the first few epochs until all data is clean and resubmit.
Posted : August 1, 2013 4:28 am
Down South
(@down-south)
Corey,
Try converting the JPS file to a later version of Rinex and see if that works.
Posted : August 1, 2013 7:10 am
corey-f
(@corey-f)
That was it, everything is working like it's suppose to now. Thanks for all the help.
Corey
Posted : August 1, 2013 8:56 pm
