Found it.....
5 Users
Last week?ÿ I posted if anyone knew of a requirement to triangulate across lakes between meander corners...
https://surveyorconnect.com/community/surveying-geomatics/glo-triangulating-between-meander-corners/
I still can't find my copy of the 1884 instructions- this seems to be happening more frequently nowadays. Anyway I went back out on Tuesday- my second trip down into there and searched- I 'd done some calcs and had a good Idea of the location based on the MC I'd recovered on the east bank and, the notes on the meander line itself, and two suspect trees. I waded in the lake and look at all the stones that were of reasonable size, figuring it may have heaved out and rolled into the water. btw, the water was about Vienna choirboy cold- The ice came off 2 weeks ago- but manageable. No Luck - I kept reminding myself of the statement my old instructor had enlightened me with many years ago... "If there's no logical reason for It not to be here, It's got to be here somewhere." As I was standing in the water, looking at the bank, I could see under a deadfall pine into an area that wasn't accessible from the upland side- and noticed at least one stone that was partially covered by a shrub growing along it's west side and over the top but covered by the pine. I broke up the pine, and cut back the shrub with my e-tool -
IMG 4802
The stone was leaning slightly to the east so I leaned down and snapped this picture...?ÿ
IMG 4801 1stshot
then I did a bit of a snoopy dance....
fulstone35
IMG 4806
It was set in May 1902, and Iƒ??m thinking it hasnƒ??t been recovered since. No evidence of any of the USFS Remonumenting efforts that remonƒ??d the other 3 corners on this line,?ÿ if theyƒ??d have found it, it would have been switched out and the line posted and blazed. The NW bearing tree had been a 30ƒ? tamarack and was a rotted log with a healed/rotted/burned blaze about the size one would expect for an MC BT. The blaze had been face up and no evidence was visible. I set a railroad spike in the stumphole and It measures out to 0.10 ft and 1^ of bearing.
The SW bearing tree was called a 16ƒ? pine- turns out it was actually a tamarack- now itƒ??s 26ƒ? dbh with a completely healed blaze. It's 1.3 ft too long in distance. but good bearing. I put BT tags on both trees and placed a side center nail in the stump of the SW BT.
?ÿI set a standard 3.25 inch mon. I'm not a fan of switching out stones for monuments, but did so because of the proximity of the stone to water and the fact that the marks on the sandstone looked highly erodible. The stone is upside down along the north side of the pipe.
The deadfall log in the back ground is the NW BT.
IMG 4810
Posted : 10/05/2019 8:09 am
Very cool, I would argue that the corner should get a pipe and cap, keep it out of the water as long as possible.
Posted : 10/05/2019 8:45 am
(@ruel-del-castillo)
"I'm not a fan of switching out stones for monuments"
Neither am I if the stone is undisturbed, solid, and hopefully has a mound around it. I like to drill a hole and put in lead and a nail and tag so others will know exactly what I located. Don't forget though.......It's the stone, stupid!
Posted : 10/05/2019 9:00 am
dms330
(@dms330)
Great effort and result Rankin!
Licensed Land Surveyor
Posted : 10/05/2019 9:28 am
when I pulled the stone out and looked it over, I refrained from brushing it with the brass brush- I wanted the moss evidence there, and the sandstone grain looked like I could practically wipe out the marks with just a couple of strokes.
IMG 4803mc
Here's the pipe and cap. It's not quite Jerry Penry stamping jig quality.... first one I've marked this season....
IMG 4807
PS my cap came pre-dimpled.....
Posted : 10/05/2019 10:25 am
(@stlsurveyor)
I'll trade you 100 miles of Mobile LiDAR work to be able to work on a project like that in such beautiful country - however, not a fan of wading in Vienna Choir boy cold water. I miss "real" surveying. Thanks for sharing
Posted : 10/05/2019 11:01 am
