This old dog needs some help learning new tricks.:-$ Can anyone point me to a good reference and/or tutorial on how to process fast static points? (I've never done any post-processing before, and the person who used to do it is gone. So I'm it.)
Equipment: Trimble R8 w/ Bluetooth, Trimble TSC2, WRSN corrections via MiFi hookup. (I'm using single station corrections right now for local RTK, but would like to include availability of surrounding stations as well.)
Software: Trimble Geomatics Office, which is apparently worthless for [msg=95316]processing now.[/msg]
Thanks in advance.
It's not a quick task to learn. Trimble Business Center and TBC-HCE has the ability to do it and it's in the tutorials. You should still get some instruction from someone who knows what's going on.
Thanks. I know that would be the best solution. However, I'm stuck with TGO.
depending on how many stations you need, the Topcon Tools demo might help (it will do 5 points in demo mode).
Thanks - I'll check it out.:-)
The HCE version is a free download
It will post processed static observations.
Have you considered using OPUS instead? Much simpler......
Thanks for the suggestions, folks. Onward! :-S
If you only have a point or two, you could submit them to OPUS. Study the tutorials and develop a work-flow then process your data and compare the results. Go to the Services>RinexDates page on here and use that to adjust the dates back to get WAVE to process your baselines.
I found this, some sort relevant to this topic 🙂 :
MythBusters: Dog Myths
:good: :dog:
TBC big download and won't install for me.
The HCE download is 1.2GB, then it won't install, wasted hours for me. might have something to do with 32 bit vs. 64 bit, but no warnings offered.
