I'm looking at costs of various common control markers. Principally relying on prices from the Bernsten, Surv-Kap, and Home Depot websites.?ÿ
- Wood Hubs are hard to get prices for and depend greatly on their length, and what part of the country you are in. Somewhere in the 50? to $1.00 range per.?ÿ Cost of tacks is nearly negligible, cost of a 3/4" mag nail is 11?. Allowing for breakage, figure maybe $1 each.
- A 1-1/2" mag nail alone is between 21? and 25?.?ÿ
- Add a stainless steel washer to it for $1.20 to $1.75, making the total cost for a MNW $1.40-$1.98. Allow a bit of cost for drilling and call it $2 each. Brass washers are much higher priced.
- The big "SURVEY MARK" spikes that emulate cotton gin spike are $1.75 each.
- Speaking of Cotton Gin Spindles, Baseline Equipment has them for 95? each. Not sure what the cost of shipping might be.?ÿ
- No.4 iron rods purchased in 24" precut lengths is nearly $5 a pop at Home Depot. But if you buy 10 foot lengths for $6.55 and cut them yourself that's $1.31 each. Add a plastic cap?ÿ for about 52? to 62? per. Call these $2 each also.
- 5/8" rebar are no longer sold at HD or Lowes in my area. On line search has the prices at more than double that of 1/2".?ÿ?ÿ
- 1-1/8" brass plugs go for $2.95 ea. if you buy 100 at a time. Allow some cost for drilling and call them $3.25 each. I like to add some epoxy, making the cost around $3.50 each?ÿ ?ÿ
After that we go to aluminum capped rebars at over $10 a pop. Brass disk to be set in concrete are going to be well over $20 each.
I haven't included the cost of shipping in any of this. That's not going to be trivial.?ÿ
Don’t you have “a guy” that provides these things in your area? That guy in my neck of the woods goes by Steve who drives up and down the I-5 corridor making deliveries. Also get to catch up on the latest Survey Company gossip/drama.
Baseline Equipment, a local supplier of cotton gin spikes, is an Oregon Company and a SurveyorConnect supporter. I'm not on their regular rounds. I don't often see cotton gin spikes in the wild in this area, so I'm not certain many are. Very little cotton is grown in the PNW.
The "Survey Mark" spikes are more common. As for the other things, if bought locally the shipping cost will be built into the retail price.
I typically cut #4 rebar with my chop saw, and as you suggest the longer lengths are more economical. I chamfer the ends a bit with my bench grinder, which is a bit of a pain. I did buy a few of the 5/8" x 18" steel form stakes at home depot but they are nearly 6 dollars each, but have such a nice point. For traversing I use the 6" mag spikes which run about 40 cents apiece. I also use 8" galvanized nails to mark along lot lines. They run about 80 cents each. I have a Lowes contractor card which gives me 5% off on any purchase. In the past I made my own concrete monuments with a brass screw embedded on top and rebar within. Not sure what that would cost now.
A 60lb bag of concrete mix is over $4 right now. But the big cost in that type of monument is going to be in your time, both building it and setting it.
I used to use wood stakes (wedges or cut down 1"x1") with tacks, but they rot away quickly, and it's surprising how often you return 5 years later and could really use that control point, if it was still there..
So have been using the Ecostakes from Bernsten. They are plastic and have a magnet inside. I drive them flush and set one of their other plastic stakes next to it as witness (or use no witness for stealth surveys). I think they cost $5 to $6 a piece, but I'm low volume, and might use only 3 or 4 per job.
My alternate would be #5 rebar driven flush with a Morasse "survey Mark" cap, especially for hard ground.
Since I work mostly in suburban lawns, I like the Ecostakes particularly because if a homeowner happened to hit one with a lawnmower, it probably wouldn't kill anyone, unlike a rebar.
I’ve been quite the fan of mag hubs over the past 3-4 years for control points. Can carry a bunch in my pocket, cheap, will sting up (unlike hub&tacks), and won’t rot if I come back to it in a few years like hub&mags. About $0.54 per 8” nail, $0.41 per 6” nail, and $0.17 per 4” nail.
@gordon-svedberg i chamber the edge of the rerod by just spinning it on the side of the chop saw blade takes 4 seconds
I've been setting 3/4 inch iron pipes which are currently $90 for a 21' length at your local NorCal Ace hardware which renders nine 28" long corner monuments (I believe it was $45/length pre-pandemic) . Add in a mortar plug and a 1 1/2 inch #4 brass screw and tag and it's probably around $12 per corner.
I recently scored a pile of gently used 3/4 and 1/2 inch galvanized pipe on a buddy's remodel job so I will be set up for a few years at a low, low price. Also the rust and faded patina on the recycled gear gives my corner monuments some street cred that the shiny new pipes just cannot match....
Also I cringe a little bit every time at the idea of cutting up perfectly good brand new pipe.
I get my irons from the local concrete supply house. Years ago one of the local survey supply dealers told me that is where they bought irons and they are closer to my place that any dealers are. Last time I bought 24" #4s (in January of 2022) they were $1.90 each. They are nicely done & I don't have to waste my time picking up long sticks and cutting them. At a billable rate of over $2 a minute they are way cheaper than cutting them myself (I can use that time on Beerleg). I use a rebar driver to set them which leave a nice chamfered edge to set the cap on.
P.s Thanks for the reminder, I need to get more irons.
Local Ace Hardware and dealer in all things handy charges his worker time to cut 20-foot lengths of #4 rebar into 2-foot lengths, plus the very reasonable cost of the long pieces. Typically, get 300-400 pieces at a time that are bundled and hoisted onto the bed of my truck for me.
The owners are also excellent clients for my work, so some of the pieces have come back to whence they came.
I agree that paying to have having something like this done is frequently worth the price. The unspoken assumption is that the time you spend doing it yourself can be employed more productively doing something else. If you have staff that needs something to do on rain days, for example, cutting rebar may be just the thing.
Steve
I know Steve!
Lots of good gossip; Steve has his finger on the pulse of the survey community around here...
And it goes pretty quick if you have one of these:
There were several other tools that showed up in my Google search.
A cut off wheel on an angle grinder works quickly and provides a squared off "dowel cut".
