CHC Landstar 7 Transformation
2 Users
(@mov_hp)
Hello
I faced this issue recently. The local Fahud UTM40 points appear correct in Esri but in Landstar these are off by few hundred meters. And therefore the base is not able to relay corrections. Any suggestions how to resolve this issue? I use the same transformation formula in Landstar as in Esri. Does field software handle transformations differently? Or should I just work with Site Calibration and forget this transformation?
Sincerely
Posted : 09/06/2022 1:30 am
(@stlsurveyor)
Sounds like a simple transformation issue.?ÿ Have to tried converting the UTM coordinates to WGS84 Lat/Long to see if the check? Is the base yours or a network base??ÿ?ÿ
I have heard and seen posts on this thread from other users that have experienced issues with LandStar and transformations.?ÿ
A fellow member on this forum runs this shop and is very sharp.?ÿ Have a look at his site and reach out to him.
https://iggps.com/LandStar/LandStar7.htm
Posted : 10/06/2022 2:54 am
