Carlson DC Software Bug
Using the list equipment below just start the base. Then start rover and topo / layout away for a hour or so then got to base screen to look at the base HI or any setting just out of interest ie update rate etc
But do not change anything you like what is there
Go back to stake points or store points with rover
The rod high in store points “2.00” is ignored the trip to the base and ZERO’s the calculation value in the software but is still displayed as 2.000
The displayed value is only updated for calculation purposes if there is a value change in the display value
IE DC soft looks for a rod height change in display value THEN and only the then this value is passed to the elevation calculation
IE 2.00 display = 0.00 and calced displayed as ANT elev - 0.00 if I change HR say from 2.000 to 1.999
The software notices a display change and then hands of the new HR of 1.999 to the calculation department.
The soft should compared the display to calculation HR value.
This is a serious software bug
And lord knows where else it is happening
Carlson SurCe Ver 2.41.1
New Allegro CX Ver 1.07a PIC 1.01 Logic 12
Geo 650 robot # 79 Firmware 696-03.08
Geo Radios @ 458.525 Mhz Ch 1
Sokkia Gsr1700Csx RTK L1 Two rovers, One base
post process soft Spectrum Ver 4.21 L1 dongle
Satel 3AS 1 watt, Stubby, 15cm, 30 cm GainFlex
Computer Hp Pavilion Core2 Quad
Vista 64
Nvidia Geforce 9500 GS 512mb Video Card
Autodesk C3D 2009 subscription stay here
Hi Peter,
I would suggest downloading the latest edition of SurvCE by visiting http://www.tiny.cc/survce and install the appropriate build over your earlier version of the software to see if this addresses the issue.
I've also forwarded your observations into the Carlson Technical Support staff. If you'd like to discuss your findings with a member of our tech support staff, please feel free to contact them via any of the methods described at http://www.carlsonsw.com/support.html .
Cordially,
