Carlson surface module for vertical datum shift
5 Users
(@peter-hughes-davies)
Is there a function in Carlson's surface module to apply a vertical shift to the tin model? I know I can just copy the tin model by applying a different z value to the destination (0,0,0 to 0,0,0.21 for example)and then re-tinning that. But I was wondering it there's a copy function with the delta z as a built in component. I remember Eagle Point used to have something like that.
Thanks in advance . .
Peter
ps I see Ladd Nelson had a solution using "tinutil" function but that seems to need Carlson Takeoff.
Posted : May 16, 2012 3:33 pm
(@spledeus)
Does the standalone have Triangulation File Utilities under the Surface menu?
Posted : May 16, 2012 5:49 pm
(@navaran)
Carlson Survey>Surface>Triangulation File Utilities>Load TIN File>Next>Add Value
Posted : May 16, 2012 9:41 pm
Thanks folks,
I feel much better now . .:-D
Peter
Posted : May 17, 2012 3:40 am
(@spledeus)
i was getting there 😛
Posted : May 17, 2012 5:27 am
(@roadburner)
That must be inside the Civil module. The survey 2012 menu doesn't have that item. I just move the triangles up or down and re-tin.
Posted : May 17, 2012 7:44 am
(@ladd-nelson)
There was a menu/command oversight in pre-2012 versions of Carlson Survey where the Triangulation File Utilities command was errantly left out of the menu-pull. It's TINUTIL key-in equivalent should still work in these previous versions. The command should be available in 2012 Survey menus. Look for Surface -- Triangulation File Utilities.
Ladd Nelson
Posted : May 17, 2012 8:18 am
(@navaran)
Exists in Carlson Survey embedded AutoCAD and in Carlson Survey with IntelliCAD/AutoCAD module
Posted : May 17, 2012 8:19 am
(@roadburner)
> Ladd Nelson
Thanks, Ladd. Looks like I still have the 2011 menu loaded. I'll fix it 🙂
Posted : May 17, 2012 9:19 am
