Carlson prob
5 Users
 hack
(@hack)
I have loaded 2 images . The first is what the stacked curve annotae menu should look like with the delta highlighted. The second is what i get. I tried support with no luck so far.
I am thinking there is a setting somewhere that causes this. Any ideas?
M.Hack
Posted : February 24, 2011 12:34 pm
(@kris-morgan)
Is triangle not delta? I don't see the problem. You selected to have the triangle symbol appear and it appears.
Posted : February 24, 2011 1:23 pm
 FLS
(@fls)
Hack if you don't like the triangle use the custom arc label selection below stack and choose the Option on the command line. You can change it there if needed.
Posted : February 24, 2011 5:08 pm
 hack
(@hack)
Let me expalin myself again. The problem is that in the stack command menu the option for delta angle has disappeared. It wass there previously and is there on other stations in our office.
I know how to work around it but i don't want a workaround. The question is how do I get back the correct menu?
Posted : February 25, 2011 4:52 am
(@snoop)
uninstall and reinstall?
Posted : February 25, 2011 6:23 am
 FLS
(@fls)
Hack mine program also has it greyed out...
Posted : February 25, 2011 9:12 am
 hack
(@hack)
Mine isn't greyed out. It is completely gone. Funny thing is that is was there yesterday. I am wondering if there is a toggle somewhere.
M.Hack
Posted : February 25, 2011 9:18 am
(@ladd-nelson)
I couldn't replicate the problem. A few questions:
1. If you click Help -- About Carlson, what build number are you running?
2. What version of CAD (AutoCAD version and/or IntelliCAD version) are you running?
3. If you re-start the command (specify Options if needed) and click the Save button, would you be willing to send me the resulting *.ANS file? If so, please send to:
lnelsonATcarlsonswDOTcom
Ladd Nelson
Posted : February 25, 2011 9:31 pm
