Carlson : No EDM shot on Set angle and read
1 Users
TNT
 TNT
(@tnt)
Firstly. No I did not hit angle only. I tried this three times including backing out of hte app and restarting stakeout mode.
This is not the first time this has happened and I am not sure what the cause is , something I am doing wrong of course.
Control point was nudged, so last week it was relocated with a set collection. Coworker did the locating.
This week I setup on on the new point and backsight whence we came, and it set 0 but did not take a distance measurement.
Tried three times as stated above. Finally staked out backsight, checked.
Checked into second point, that checked.
Continued on our day.
In the past when this has happened I have generally backsighted the point and then just relocate it as a new point and backsight that to record the deltas. Not ideal.
Has anyone come across this before? Carlson Tech support does not know (assumes Angle only)
thanks
OC,OP4377,N 65922.70279,E 13933.74047,EL445.636,--NB-208 4372 REPLACEMENT FOR MONITORING
LS,HI5.1550,HR4.9700
BK,OP4377,BP4321,BS201.1956,BC0.0000
BD,OP4377,FP4321,AR0.00000,ZE88.52370,SD,--REBAR/CAP NB-208
BR,OP4377,FP4321,AR180.00000,ZE271.07210,SD,--REBAR/CAP NB-208
--SS,OP4377,FP4321,AR0.00000,ZE88.52380,SD,--REBAR/CAP NB-208
--Calculated: AR0°00'00"
--Measured: AR0°00'00"
--Delta: AR0°00'00"
Posted : May 16, 2023 12:33 pm
