Best way to Clean sand from TSC3 - Bottom boot area
gisjoel
(@gisjoel)
Hello,
The TSC3 I'm looking at spent some time along the sandy marine coast in AK.?ÿ Opening the boots, show fine sand around the ports.Being rubberized, sand is particularly adherent to the chassis of the TSC3.?ÿ Any advice would be great on how to remove sand, and keep the particles out of the ports (USB) while doing the cleanse.
Joel
Posted : July 9, 2019 11:00 am
jerry-hastings
(@jerry-hastings)
Have you tried canned air or a air compressor??ÿ I would start at a angle and see if it will let go before I went straight into it.?ÿ Good luck.
Posted : July 9, 2019 12:03 pm
gisjoel
(@gisjoel)
I have that Jerry.  I'm not a fan of it in this case with sand tightly encased around rubber port doors.  The rubber on the TSC3 is particularly sticky  - makes for a great hand hold, but man - it grabs and holds onto sand. And then there is the open ports.
joel
Posted : July 9, 2019 12:23 pm
jerry-hastings
(@jerry-hastings)
Yes, I know the rubber is particularly sticky for sure.?ÿ I use a TSC3 a lot too.?ÿ The TSC1 and TSC2 do not have the same problem.?ÿ Maybe try an old toothbrush?
Posted : July 9, 2019 12:40 pm
va-ls-2867
(@va-ls-2867)
Use a vacuum with a brush attachment. Maybe a small paint brush to loosen particles beforehand.
Posted : July 9, 2019 12:48 pm
Plug something into the open ports first for the initial rough cleaning compressed air blowing phase. ?ÿThen get out the tweezers for the fine cleaning open port phase. ?ÿLook at the task as an opportunity for some mindful meditation.?ÿ
Posted : July 10, 2019 6:45 am
