Anyone ever add radio module to TSC3?
(@totalsurv)
Just wondering if anyone has successfully added a radio module to a TSC3 themselves? I have a TSC3 setup for use with gps and was hoping to make it useable with an S6 as well. I can get the parts from Kargotech but don't want to attempt if it's not possible without some sort of software upgrade as well. Already have access 2017 onboard
Posted : December 3, 2022 1:58 am
(@jitterboogie)
the parts of in good working shape should assemble easily.
The software is a whole other mess....
you'll likely need Trimble rep to get you past that and be functional.?ÿ wild guess.
good luck and let us know what happens
Posted : December 3, 2022 6:24 am
(@350rocketmike)
@jitterboogie?ÿ
You probably have to pay for a robotics module as well.?ÿ
Posted : December 3, 2022 10:59 am
(@bstrand)
I'm kinda curious if anyone has added a radio to the TDC600 as well??ÿ I don't know much about it but it sounds like it works similarly.
Posted : December 3, 2022 11:16 am
(@350rocketmike)
@bstrand?ÿ
You have to purchase a separate radio module (tdl2.4) same as if you want to use access with a third party tablet like the Panasonic fz-m1. The module was around $2500 I think. I asked for one but instead I got a tsc7. Maybe for the better since access workflow seems to only be efficient if you use all the hot keys you can, but the Panasonic was a much more dependable unit.?ÿ
Posted : December 3, 2022 12:00 pm
(@bstrand)
@350rocketmike
I see.?ÿ Any idea if a TSC5 comes with the robot radio built in or is that extra too?
Posted : December 3, 2022 12:30 pm
(@350rocketmike)
@bstrand?ÿ
They are externally attached as a module to the back of the tsc5/7. I still have the same radio on the tsc7 that I had on the tsc5. They just replaced the data collector itself.?ÿ
I didn't realize the tsc3 had internal radios. We never used one with a robot before so none of ours had one. By the time we bought S series they were already switching everyone to tsc7's.?ÿ
Posted : December 3, 2022 12:48 pm
(@bstrand)
@bstrand?ÿ
Right, but did you have to pay an extra $2500 for the radio on the TSC5 as well?
Posted : December 3, 2022 1:03 pm
(@350rocketmike)
@bstrand?ÿ
I'm not the one paying for the equipment, but this is from the distributor my employer buys from...
Screenshot 20221203 160640
Screenshot 20221203 160808
Screenshot 20221203 160818
Screenshot 20221203 160714
Screenshot 20221203 161016
?ÿFor some reason they don't list a tsc5 or 7 with the radio. But price is likely around $2500 like the external one.?ÿ
Posted : December 3, 2022 1:12 pm
(@totalsurv)
Anyway........if anyone has added a radio module themselves to a TSC3 I would like to know if it's possible. Thanks.
Posted : December 3, 2022 2:58 pm
(@olemanriver)
It is possible. Here is the biggest issues you will run into. ?ÿOne the TSC3 is no longer supported. I bought a battery for one about 6 months ago at the dealership he said he had one battery left and they were not stocking anymore. ?ÿI have a few TSC3 already with the radio built in. It is not hard to attach them or take them off. Its screwƒ??s really is all. Very simple. The next issue is where do you find one. I would reach out to your local dealer and Build a Relationship with them. You might get lucky and they have a used one laying around from a dead TSC3 that was attacked by gravity or stabbed with a range pole being sarcastic. And see if they can upgrade your software if it is not already which it could already be for robot. ?ÿThis is easy to check for them. The other alternative is to do a little playing with the numbers. ?ÿAnd buy a new data collector like TSC7 or TSC5 and transfer your current Trimble Access license to the new TSC7 or TSC5. ?ÿSometimes a good salesman knows the tricks to save you a little money. I did this not long ago. Example my tsc3 was about done for. I paid the maintenance agreement to get it under the ability to upgrade from a 2014 version to the latest 2017 version for access on the tsc3. We bought a tsc5 and no license but transferred the access license from the tsc3 to tsc5. We saved a couple grande playing the numbers game. Because of the new cost of access was higher. Now once access was on the tsc5 it was still under warranty and it was updated to the latest software version. I see two options for you. Find out first what you have on your access robot gps etc. then find out if you can even get it to robot before proceeding to finding a robot module for your tsc3.?ÿ
Good luck. ?ÿAre you a solo operator on tight budget. If so PM me what geographic area you are in. I might have a dead tsc3 that I might can wiggle on and get the software key and send you the radio module and access key but you will need to have the dealer get it tied to your sn#. Of your tsc3. Build those relationships. ?ÿYes they are salesman women. But you will be surprised how a good one will figure out a way to help you when in need. A bad one i donƒ??t bother with. I have a good one here. And he has been around for a long time in the industry. He knows when someone starts out every thing is tight. He really helps them all he can. He has to eat to though.?ÿ
Posted : December 3, 2022 7:12 pm
Yes, works well. Still running the S6.
Posted : December 4, 2022 1:14 pm
