ALTA Item 22
5 Users
ppm
 ppm
(@ppm)
Lenders council asking us to add item 22 in the certificate.
(The filled in 22 in their request, stating that they wanted tax lot numbers for the property and the adjoining properties).
Do you add 22 in the certificate?
Posted : February 23, 2017 11:58 am
jimmy-cleveland
(@jimmy-cleveland)
PPM,
As per Gary Kent last week at the KAPS conference, no. The proper number for that request would be 21a, 21b, etc. Any additional items negotiated would simple be the number 21, with an a, b, c, added for each item.
Jimmy
Posted : February 23, 2017 12:04 pm
jered-mcgrath-pls
(@jered-mcgrath-pls)
Jimmy Cleveland, post: 415555, member: 91 wrote: PPM,
Jimmy
Yep, 22 was MISC for the 2011 standards. 21 is for current 2016 standards and yes I would have no problem stating 22 in cert and a survey note explaining optional item 22 Is for the inclusion of tax lot numbers for the property and the adjoining properties as per the ________ county Assessors records at the time of this survey..... or something of that nature as it is spelled out in your contract with the client.
Posted : February 23, 2017 2:12 pm
jimmy-cleveland
(@jimmy-cleveland)
Jered McGrath PLS, post: 415577, member: 794 wrote: Yep, 22 was MISC for the 2011 standards. 21 is for current 2016 standards and yes I would have no problem stating 22 in cert and a survey note explaining optional item 22 Is for the inclusion of tax lot numbers for the property and the adjoining properties as per the ________ county Assessors records at the time of this survey..... or something of that nature as it is spelled out in your contract with the client.
Jered,
This very question came up last Friday during Gary's seminar on ALTA/NSPS surveys. He advised us to use the items as I outlined above because there is NOT an item 22 in the current, approved 2016 Table A. Just passing along what he said last week.
Jimmy
Posted : February 23, 2017 3:33 pm
ppm
 ppm
(@ppm)
Thanks guys...
Another one that came up a while back that I got asked... If they check Table A number 20. Do you put 20 in the Certificate on the map? I could have swore that I ready somewhere that it could be left out of the certificate. I would think it should be in there. Any thoughts on this?
Posted : February 23, 2017 3:41 pm
spotteddog
(@spotteddog)
The ALTA minimum requirements mentions this in Section 6 D ii (g). I would use 21(a), 21(b)... with explanation of each.
Posted : February 23, 2017 4:01 pm
jered-mcgrath-pls
Jimmy Cleveland, post: 415597, member: 91 wrote: Jered,
Jimmy
Jimmy, I was in complete agreement with you, I just mistyped 22 for 21 on the last two references too it in my prev post.. I keep the ALTA regs no more than an arm length away. Cheers
Posted : February 23, 2017 8:04 pm
jimmy-cleveland
(@jimmy-cleveland)
Jered McGrath PLS, post: 415654, member: 794 wrote: Jimmy, I was in complete agreement with you, I just mistyped 22 for 21 on the last two references too it in my prev post.. I keep the ALTA regs no more than an arm length away. Cheers
No big deal, Gary stressed, in my opinion, that the standards help protect us as surveyors. I'd hate to see ANY surveyor get caught up in a technicality by some party trying to shift any more liability to our profession than we already assume when we sign a survey.
Posted : February 24, 2017 7:30 am
jhenry
(@jhenry)
ppm, post: 415600, member: 6808 wrote: Thanks guys...
You would put item 20 in the cert, but you do not specify the amount of coverage you have, that is not necessary .
Posted : February 24, 2017 10:15 am
