Allegro CX Screen Replacement
7 Users
About a year ago my Allegro CX screen died. I was in the middle of a time-sensitive project, so rather than explore repair options I bit the bullet and had a new Surveyor+ overnighted to me. I've been using the Surveyor+ ever since, but having the Allegro just sitting there kind of bothered me. I didn't think it was worth having Juniper Systems replace the screen (though I never did actually get a cost estimate), at least in part because I had heavily hacked the Allegro to accommodate a Parani radio. A couple of times I searched for a replacement screen, but came up empty. That puzzled me, because replacement screens for so many devices are readily available, on eBay if nowhere else.
Last week I decided to give it another go, but this time I opened the Allegro to see if I could find a part number. I was in luck, the screen was made by Sharp and had a part number of LQ038Q7DB03 on it. A search on eBay using that info turned up a replacement; apparently the same screen is used in the Motorola Symbol. The cost? A whopping $4.99 plus $3.65 shipping. I figured I didn't have much to lose, so I ordered it.
Here's a photo of the contents of the padded shipping envelope:
Opening the Allegro is pretty straightforward: lay the unit face down, remove the 10 machine screws around the perimeter, then carefully fold the back to the right so as not to strain the internal cable connections. The shot below shows the unit open. (I had already disconnected the cable from the screen to the motherboard.)
The connector cable pushes onto the motherboard, but the other end uses a tiny hinged connector to secure the flat screen connector. There are a couple of itsy-bitsy plastic clips on the hinged connector that broke when I detached them. We're talking really small, maybe half a millimeter. I was pretty gentle, so they may not be designed for reuse. It's not a big deal, as a piece of electrical tape serves just as well to keep the connector "door" from coming open. (I should have taken more pics, but I was kind of in a hurry.)
Getting the screen into its rubber surround and located in the housing is a little tricky, and more photos during disassembly would have been useful. It took me several tries to get it right, but I got there. Reassembling the Allegro is also kind of tedious, at least if you want to retain the strap rings that are located in the 4 corners. They used some little stainless steel brackets that have to sit loosely between the two halves of the case, and getting all 4 into place at the same time requires patience. I never used the strap clips and thought about just leaving them out, but decided to go ahead and take the time to retain them. Once they're in place, it's just a matter of tightening the machine screws.
Then the moment of truth, or so I thought: I installed the battery, hit the on button, and she lit up, running through the boot sequence and loading WindowsCE. That's when I found out that the moment of truth was only a partial truth: The screen worked fine from the keyboard, but the touch function was wonky. I tried calibrating the screen, which involved tapping on a cross as it moves to various places around the screen, but the most I could get was the first two taps, then it wouldn't respond.
I prefer to run SurvCE from the keypad, but I'm not sure I can access every needed function that way, so I'd like to get the touch function working. At worst, I'm out about 8 bucks and an hour or so of my time right now. But I'm so close to having a fully-functional backup data collector that if anyone has some tips about touchscreens, I'd love to learn about them.
Thanks!
Posted : August 18, 2016 7:45 am
(@kris-morgan)
Way cool. I have nothing to add other than it's just cool.
Posted : August 18, 2016 11:26 am
(@scott-ellis)
Jim,
The only way I know how to do is the same way you did. Go into windows find the settings menu then screen calibration touching the plus in the four corners and middle of the screen.
At least you now have a back up data collector to use, and won't have to pay for overnight shipping on the next one, which would be more than 8 dollars, so you did come out ahead.
Posted : August 18, 2016 12:20 pm
(@scotland)
Jim- from your write up, it sounds like you had a little bit of difficulty. Wonder if when you broke the clips for holding the cables that you don't have a tight clamp now. Might go back in and check those connections and make sure they are aligned too. Just a mm left or right makes a difference too. Good luck
Sent from my SM-T530NU using Tapatalk
Posted : August 18, 2016 6:04 pm
I don't know the answer here, Jim. Some types of hardware are sensitive to a static discharge (warning label on package). Do you have a good bench ground? Ground yourself out before touching the part?
Posted : August 18, 2016 6:17 pm
What I'm learning - I think - is that the replacement screen is working fine, but that it's only the display. The part that handles the touch sits above the display, and is malfunctioning. The old display was dead for sure, and the new one seems okay. I think the touch part was working before, so I may have disturbed its cable while mucking about.
It's time to open it up again...
Posted : August 18, 2016 6:46 pm
(@flga-2-2-2-2-2-2-2-2)
Can I just send stuff to you for you to fix? For the six years I have "known" you it seems you can fix anything electronic! 😎
Posted : August 19, 2016 3:20 am
FL/GA PLS., post: 387068, member: 379 wrote: Can I just send stuff to you for you to fix?
You might not be so anxious to send me stuff once you learn that I don't post photos of the ones that "died on the table."
Posted : August 19, 2016 6:14 am
(@johnymal)
Jim I have the same problem with my allegro cx the touch of the screnn does not respond any more.. Did anyone fixes allegros screen or it is easy to try it in my own?
Your allegro works well now?
Posted : September 22, 2016 10:10 am
johnymal, post: 392216, member: 7096 wrote: Your allegro works well now?
I haven't done much testing -- I have way too much work on the books to devote any time to it right now -- but near as I can tell it works fine long as keyboard input is used. The "touch" part of the screen isn't working, and it was only after I had put it back together that I realized that the display and the digitizer are two separate hardware components. I may have accidentally disabled the digitizer during reassembly, or it may be broken. I ordered a replacement through eBay -- it only cost 6 bucks delivered - so when I do get time I'll replace it and see what happens.
Posted : September 22, 2016 12:59 pm
