Wipeout Text
8 Users
How do I "wipeout" the hatching immediately around this building dimension text?
Or, is there a better method all together than what I am doing?
I am just highlighting the existing building on site with this cross hatching method I learned about 7 years ago. My gut tells me there is a better way. I have tried to do the grey solid shading, but my experience is that while it may look good on the initial pdf, results may vary on other's printers, etc...
Posted : March 5, 2013 2:47 pm
va-ls-2867
(@va-ls-2867)
If you include the text in your selection set for the hatching, the hatch will go around the text.
Posted : March 5, 2013 3:10 pm
Explode the hatch and erase the overlapping hatch.
ouch
Posted : March 5, 2013 3:14 pm
duh. perfect. thanks Jason.
Posted : March 5, 2013 3:15 pm
SurveySEAK
(@surveyseak)
You can also convert it to Multi-Text, if it isn't already (use the TXT2MTXT command) then go into properties and check on the Background Mask command. I'm not sure which version they introduced that command, maybe 2012 or 2013, but I use it a lot. The background can be set to match the background color, or to a specific color.
Posted : March 5, 2013 3:22 pm
ladd-nelson
(@ladd-nelson)
Another option in Carlson can be employed via the Draw -- Text -- Text Mask command. With this option, you wouldn't have to re-do the hatch.
Posted : March 5, 2013 3:29 pm
Interesting Ladd. I have been intuitively been looking for that under EDIT --> TEXT with no luck. Thank you!
Unfortunately I get this now:
Oh well.
(By the way I just emailed Lon with some more contour struggles, I suspect it is a minor issue at my end, do you think he will be able to respond tomorrow?)
Posted : March 5, 2013 3:47 pm
Ladd & Lon
Never mind. Lon just called.
Ladd & Lon (Lat & Lon) ~ coincidence, I don't think so.
Posted : March 5, 2013 4:18 pm
christ-lambrecht
(@christ-lambrecht)
Ladd & Lon
:good:
you're sharp!
Chr.
Posted : March 5, 2013 4:24 pm
andy-j
(@andy-j)
> ouch
yeah, nothing like using a sledge hammer on a watch! 😉 then later when you want to change the hatch it's a real pain!
Posted : March 5, 2013 4:36 pm
Or, almost as clever a plan:
Plot the survey
Use whiteout to cover the hatch
Hand letter the dimensions back in
Posted : March 5, 2013 4:50 pm
