AutoCAD xref wipeout
Jeremy Hallick
(@jeremy-hallick)
Good morning everyone.
I am preparing an asbuilt where I would like to have certain items that need to be on every page Xref'd into paperspace. I have used the wipeout command for those xref files and was hoping to have the xref wipeout everything behind it when I move it to the location on the page it belongs. However, when I bring the xref items in, it will only wipeout items that are in paperspace and not model space. It will wipeout the viewport line but I can still see everything behind it that is in model space. I have tried the draworder but nothing seems to work.
Any ideas on what is going on with this is greatly appreciated.
Regards,
JH
Posted : March 5, 2013 7:18 am
RFB
 RFB
(@rfb)
I don't know if this will help,
but
I had a similar problem with a "legacy" (old) version of ACAD, believe it or not, I had to reverse the draw order in paper space to make it plot correctly.
It seemed counter intuitive, but it worked and it's worth a quick try.
Posted : March 5, 2013 7:22 am
Jeremy Hallick
(@jeremy-hallick)
Do you mean sending the viewport to the front?
Posted : March 5, 2013 7:25 am
stephen-ward
(@stephen-ward)
Look for a check box in the print dialog that is labeled "plot paperspace last" or similar. By printing paperspace last your wipeouts should hide objects in modelspace.
Posted : March 5, 2013 7:32 am
Jeremy Hallick
(@jeremy-hallick)
That did it. Thank you for your help!
Posted : March 5, 2013 7:35 am
