TSCE questions
(@jawja)
Just got this thing. Looks nice, but have an issue. How do I connect the confounded thing to a Windows 7 pc that ain't got a serial port? Bought a serial 9 to usb but no bueno. Any help will be appreciated. Do have a rev a multiport.
Sent from my SM-G955U using Tapatalk
Posted : May 25, 2017 3:53 pm
(@detritalgeo)
In the past I have had luck with the dsub-15 multiport adapter. These are made by trimble and usually there are a few on Ebay. Some give you a USB port and some give you a dsub-9 serial port.
Posted : May 25, 2017 7:37 pm
(@jawja)
detritalgeo, post: 429955, member: 8326 wrote: In the past I have had luck with the dsub-15 multiport adapter. These are made by trimble and usually there are a few on Ebay. Some give you a USB port and some give you a dsub-9 serial port.
I got the usb port one. Dumb question but do they make a usb cable with two a male fittings? I can get internet access through the cat5 port but cannot share the drive as it is Windows ce 4.
Posted : May 25, 2017 7:43 pm
(@detritalgeo)
Jawja, post: 429956, member: 12766 wrote: I got the usb port one. Dumb question but do they make a usb cable with two a male fittings? I can get internet access through the cat5 port but cannot share the drive as it is Windows ce 4.
The usb B to usb A cable should work, or just borrow a USB cable from a local printer to test.
Posted : May 28, 2017 1:36 pm
(@jawja)
I do not understand. My multi adaptor has an a female slot. My computer has an a female slot. How would I transfer with an a male b male cable. I could use that to hook to printer, but that would not help. Or are you suggesting buy an external HD and use cable to connect to it?
Posted : May 28, 2017 2:32 pm
(@astrodanco)
The correct multi-adapter should have a USB-B jack. Use a USB-A to USB-B cable and Windows Mobile Device Center software to map the TSCE as a disk drive. If you're in a huge hurry you can always open up the TSCE, pull the memory card out and put it into an adapter.
Posted : May 28, 2017 5:36 pm
(@detritalgeo)
Jawja, post: 430228, member: 12766 wrote: I do not understand. My multi adaptor has an a female slot. My computer has an a female slot. How would I transfer with an a male b male cable. I could use that to hook to printer, but that would not help. Or are you suggesting buy an external HD and use cable to connect to it?
Most printers these days use a USB B to USB A cable, which is exactly what you need. I just thought if you had a normal ink jet printer you could just borrow the cable instead of buying a new one. Or just buy a USB-B male to USB-A male cable and try it out..
One like this: http://www.ebay.com/itm/121230515204
Posted : May 28, 2017 7:55 pm
(@jawja)
Finally got to download. Cat5 to router. Router has usb drive. Usb transfer to pc. People I bought tsce from deleted activesync.
Posted : June 3, 2017 3:10 pm
(@detritalgeo)
If you record all licence details about the Survey Controller software, you could re-install the OS to bring active-sync back.
Only recommend if you are families with reseting mobile devices to factory spec.
Posted : June 3, 2017 4:12 pm
