Is there anywhere I can get a list of commands for the TSC-2 (Trimble Survey Controller Ver. 12.50)??ÿ In other words instead of pointing the sylus on the screen I'd like to use keystrokes. ?ÿ
Commands such as the following -
To access the softkeys using the keyboard:
On a Trimble TSC2, press Ctrl and then 1, 2, 3, or 4 for softkeys F1, F2, F3, or F4 respectively. To
display the second row of softkeys, press Shift.
can be found in the Trimble Survey Controller "Help" PDF which is available for free download at trimble.com.
HTH
GB
This is late but thanks for the reply.?ÿ I looked throughout my manual but couldn't find anything, your reply helped out
My Favorites, but I'm sure you know these already
CTRL-R Review Job
CTRL-M Map View
CTRL-N Note input - here you can also check the time
CTRL-B Battery
and?ÿ
CTRL-C and CTRL-V to copy and paste between input boxes or notes.
