Trueview 2013 question
(@francish)
In autocad, when lines like contours & roads are drawn crooked you could issue a REGEN command to redraw the lines and make them smooth as they were originally drawn. I guess the crooked lines were a way to cheat to make the drawings load faster.
Anyway when I open the same drawing in Trueview 2013, the lines again appear crooked but I could not issue the REGEN command to make them smooth. Is there a setting somewhere in TrueView?
Posted : September 18, 2015 4:31 pm
(@ladd-nelson)
FrancisH, post: 336999, member: 10211 wrote: In autocad, when lines like contours & roads are drawn crooked you could issue a REGEN command to redraw the lines and make them smooth as they were originally drawn. I guess the crooked lines were a way to cheat to make the drawings load faster.
You should be able to increase the "Arc and circle smoothness" setting cleverly hidden under the Options wrench near the Command line:
Posted : September 18, 2015 5:27 pm
(@francish)
Thanks Ladd, never saw that settings icon,
Posted : September 19, 2015 1:09 am
(@jbstahl)
VIEWRES Command. I set my default drawings to 20000. Back in the old ACad days, having a high viewres meant longer/more frequent regen times during zooms & pans. Pretty irrelevant with today's processors.
Posted : September 19, 2015 6:21 am
