Topcon reciever to Spectra survey office or TBC
2 Users
callen
(@callen)
Trying out survey office (stripped down TBC) and trying to post process CORS, Spectra GNSS, and a Topcon hiper ga data.
Topcon imports as a RINEX file after manually adding receiver/antenna make/model/height in 2 tabs on import screen, but fails to process the baseline. Import error report says it's an invalid serial # on reciever and can't create a valid antenna.
File processes through OPUS.
Dealer is looking at it trying to help, but has anyone been able to make Topcon/trimble play nice? Not a newbie to processing (ashtech/topcon tools) but I'm a bit stumped. Used TopLink to create rinex and even a rinex3 format from native TPS log file.
Any ideas appreciated.
Posted : August 10, 2016 6:30 pm
Make sure you have the correct antenna model set (I suggest NGS Absolute) and ephemeris type specified in the Project Settings | Baseline Processing | General box. If you specify precise ephemerides and try to process with only the broadcast imported, it'll fail.
Posted : August 10, 2016 8:09 pm
callen
(@callen)
Thank you Jim. That makes a little more sense now. I was pulling down the NGS absolute, but it didn't recognize topcon automatically.
The ephemeris type was not on my radar, so I'll check on it too.
Posted : August 11, 2016 3:55 pm
