"THERE IS NO POINT WITHIN GIVEN RANGE DO YOU WANT TO PROCEED WITH MEASURING THIS POINT?"
We keep getting that message before collecting EVERY shot. It will not collect the shot unless you hit YES. It's annoying when you have hundreds of shots to take! We are not setting corners or doing any layout. (FC-5000) Tried a soft reset and a hard reset, no luck.?ÿ
ANY IDEAS??ÿ
Posted : June 15, 2020 4:22 am
Go to Configurations in stake out toggle off range setting. It is looking to stake the nearest within the defined range.
Posted : June 15, 2020 10:25 am
To be more specific go to
Configure >Survey
Edit your current Optical Configuration
Next through settings until you see "Point Naming" at the top bar.
Now Toggle off "Measure nearest" or change the Range
Posted : June 16, 2020 5:46 am
Thank you very much!!!!
Posted : June 16, 2020 5:58 am
