Terramodel Links Questions
2 Users
dbussie
(@dbussie)
I'm hoping someone will be able to help me with this.
First of all I'm having trouble getting the links to display. Sometimes they will, sometimes they won't. Has anyone experienced this?
Secondly, being a Civil 3d user, I'm used to being able to clean up the triangles on my surface. How do I clean up areas that my dtm is linking where it shouldn't in Terramodel? For example, like the attached image. (Not sure if that worked or not)
Any help would be appreciated.
Desirea
Posted : February 10, 2014 10:15 am
Thad
 Thad
(@thad)
Under Settings/Link Settings/ Check the box "Display links" and make sure the surface layer is highlighted, then you should see the links.
Changing the "Maximum edge distance" to a smaller number (I use 10') helps with the gaps or better define the surface in those areas using breaklines or existing information.
Hope this helps.
Thad
Posted : February 10, 2014 11:53 am
dbussie
(@dbussie)
Thank you. That is how I turn them on and I always make sure the right layer is selected but for some reason when I refresh my screen there are times that they don't show up. Is there a service pack or something that I might be missing?
I will give the "maximum edge" thing a try. Thank you!
Posted : February 10, 2014 12:43 pm
