Spectra Precision Survey Office-Export Points
(@adamwest)
I am trying to import a .survey file from the data collector into Survey Office (v2.93 free version) and then export the points in a .txt format. That seems simple enough, but all I can get out is point number,N,E,Z. I cannot get the description to export. I've tried several export formats with no luck: txt, csv, dc, and xml. What am I missing?
Posted : 24/05/2014 8:41 am
(@bobwesterman)
You need to use a custom import format. None of the predefined formats support the description field.
Posted : 26/05/2014 8:04 am
(@sirveyr)
Adam,
Have you figured out how to export NEZD yet?
File > Export > Export File Editor
Select New
Name the export format (P,N,E,Z,D) > Next
Select the Delimiter that you wish to use.
Double-click on each field (General tab) that you wish to add:
Point ID
Northing
Easting
Elevation
Description 1
Finish
I hope that this makes sense and it helps. I sent this as a PM too. I wanted to make sure that you got it.
Posted : 29/05/2014 2:19 pm
