I am not sure what part of this file to delete...
Under *** Start of Kinematic Data *** there is a row of numbers the first one is 57.0000 then it counts up to 59.000 and starts over at 0.000 counts up to 59.000... It does that all the way to the end. The logging rate is set at one second and its a 20 min observation.
2.11 OBSERVATION DATA Mixed(MIXED) RINEX VERSION / TYPE
cnvtToRINEX 2.17.0 convertToRINEX OPR 22-Oct-13 14:05 UTC PGM / RUN BY / DATE
----------------------------------------------------------- COMMENT
1 MARKER NAME
1 MARKER NUMBER
GNSS Observer Trimble OBSERVER / AGENCY
5125467150 R6-2 4.44 REC # / TYPE / VERS
TRMR6-2 NONE ANT # / TYPE
1324691.0844 -4363785.2319 4444226.4895 APPROX POSITION XYZ
2.0000 0.0000 0.0000 ANTENNA: DELTA H/E/N
1 1 0 WAVELENGTH FACT L1/2
5 C1 C2 L1 L2 P2 # / TYPES OF OBSERV
2013 10 22 13 39 57.0000000 GPS TIME OF FIRST OBS
2013 10 22 14 1 39.0000000 GPS TIME OF LAST OBS
0 RCV CLOCK OFFS APPL
16 LEAP SECONDS
17 # OF SATELLITES
G01 1303 1303 1303 2606 1303 PRN / # OF OBS
G07 1296 1294 1289 2583 1291 PRN / # OF OBS
G08 1301 0 1300 1300 1301 PRN / # OF OBS
G09 1300 0 1298 1298 1299 PRN / # OF OBS
G11 1303 0 1303 1303 1303 PRN / # OF OBS
G17 1301 1301 1297 2596 1296 PRN / # OF OBS
G19 1293 0 1288 1281 1285 PRN / # OF OBS
G20 1023 0 1018 1009 1012 PRN / # OF OBS
G28 1303 0 1303 1303 1303 PRN / # OF OBS
G32 1288 0 1280 1274 1278 PRN / # OF OBS
R01 1286 0 1283 1280 1281 PRN / # OF OBS
R14 1283 0 1282 1282 1283 PRN / # OF OBS
R15 1303 0 1303 1303 1303 PRN / # OF OBS
R16 1303 0 1303 1303 1303 PRN / # OF OBS
R17 1303 0 1303 1303 1303 PRN / # OF OBS
R18 1303 0 1303 1303 1303 PRN / # OF OBS
R24 1286 0 1283 1284 1284 PRN / # OF OBS
CARRIER PHASE MEASUREMENTS: PHASE SHIFTS REMOVED COMMENT
END OF HEADER
2 1
*** Start of Kinematic Data *** COMMENT
13 10 22 13 39 57.0000000 0 16G01G07G08G09G11G17G19G28G32R01R14R15
R16R17R18R24
20419986.438 7 20419995.672 9 107307752.29917 83616442.40719 20419995.14849
22616503.156 6 22616509.598 9 118850486.51716 92610807.02119 22616509.59448
20738147.531 7 108979697.22017 84919265.88458 20738153.54748
21030811.852 7 110517617.81217 86117673.10458 21030817.34448
20750606.711 7 109045169.83217 84970276.99658 20750611.07448
22622190.820 6 22622197.426 9 118880378.07616 92634106.02619 22622197.68048
23811471.797 6 125130096.13916 97504002.92357 23811476.57047
20860094.016 7 109620529.89517 85418608.98858 20860097.59848
24313163.250 1 127766468.80811 99558386.12055 24313174.52745
23409272.797 5 125135824.44015 97327990.37518 23409283.254 8
21884941.758 5 116658960.38515 90734823.51918 21884951.871 8
19268535.266 7 102965198.89617 80084044.74719 19268540.691 9
21281144.242 7 113680058.19917 88417819.66719 21281150.488 9
19243481.227 8 102975853.39918 80092246.25619 19243483.883 9
21135669.500 7 112823607.80217 87751717.17519 21135675.824 9
21869458.836 7 116945821.62717 90957852.66219 21869463.840 9
13 10 22 13 39 58.0000000 0 16G01G07G08G09G11G17G19G28G32R01R14R15
R16R17R18R24
20419796.594 7 20419805.098 9 107306755.536 7 83615665.705 9 20419804.89149
22617036.836 6 22617044.012 9 118853293.109 6 92612993.966 9 22617043.78148
20738340.242 7 108980709.670 7 84920054.80248 20738345.91048
21031136.281 7 110519322.584 7 86119001.49548 21031141.54348
20750796.047 7 109046165.020 7 84971052.46648 20750800.98448
22621587.180 6 22621593.809 9 118877204.964 6 92631633.478 9 22621594.05548
23811941.328 6 125132561.918 6 97505924.30047 23811946.03147
20859682.703 7 109618368.665 7 85416924.91748 20859686.58248
24312544.922 1 127763212.310 1 99555848.61745 24312554.21145
23408693.898 5 125132724.005 5 97325578.925 8 23408702.746 8
21885593.508 5 116662433.762 5 90737525.030 8 21885603.355 8
19268531.398 7 102965178.419 7 80084028.823 9 19268537.176 9
21280371.836 7 113675926.769 7 88414606.334 9 21280377.391 9
19243424.641 8 102975553.161 8 80092012.730 9 19243427.660 9
21135024.836 7 112820169.216 7 87749042.729 9 21135031.559 9
21869948.508 7 116948442.553 7 90959891.164 9 21869953.520 9
13 10 22 13 39 59.0000000 0 16G01G07G08G09G11G17G19G28G32R01R14R15
R16R17R18R24
20419607.453 7 20419616.648 9 107305759.467 7 83614889.547 9 20419616.29349
22617571.320 6 22617578.133 9 118856099.981 6 92615181.137 9 22617578.03547
20738533.094 7 108981722.783 7 84920844.24148 20738538.53948
21031460.414 7 110521028.011 7 86120330.39348 21031466.68048
20750985.656 7 109047160.803 7 84971828.39748 20750990.13348
22620983.578 6 22620989.629 9 118874032.145 6 92629161.143 9 22620990.05148
23812411.078 6 125135027.813 6 97507845.77047 23812415.36747
20859271.289 7 109616207.786 7 85415241.11348 20859275.23448
24311923.695 1 127759956.097 1 99553311.31245 24311934.78145
23408114.594 4 125129624.136 4 97323167.917 8 23408123.469 8
21886246.156 5 116665907.571 5 90740226.879 8 21886255.043 8
19268527.234 8 102965158.874 8 80084013.620 9 19268533.203 9
21279597.789 7 113671795.905 7 88411393.449 9 21279603.871 9
19243368.914 8 102975253.503 8 80091779.665 9 19243372.480 9
21134380.875 7 112816731.086 7 87746368.634 9 21134387.660 9
21870438.547 7 116951063.621 7 90961929.768 9 21870443.352 9
13 10 22 13 40 0.0000000 0 16G01G07G08G09G11G17G19G28G32R01R14R15
R16R17R18R24
20419418.008 7 20419427.059 9 107304764.113 7 83614113.948 9 20419426.74649
22618105.188 6 22618112.668 9 118858907.180 6 92617368.557 9 22618112.42247
20738726.461 7 108982736.642 7 84921634.26248 20738732.06648
21031785.172 7 110522734.058 7 86121659.76948 21031791.46548
20751175.156 7 109048157.196 7 84972604.81348 20751179.57848
22620379.750 6 22620385.941 9 118870859.542 6 92626688.984 9 22620386.16848
23812879.016 6 125137493.755 6 97509767.28047 23812884.88747
20858859.969 7 109614047.235 7 85413557.56448 20858864.07048
24311303.656 1 127756700.196 1 99550774.23245 24311315.21145
23407533.531 5 125126524.959 5 97320757.457 8 23407543.668 8
21886897.141 5 116669381.782 5 90742929.037 8 21886906.609 8
19268524.102 8 102965140.267 8 80083999.147 9 19268529.496 9
21278824.891 7 113667665.570 7 88408180.967 9 21278830.547 9
19243313.375 8 102974954.392 8 80091547.021 9 19243315.660 9
21133737.188 7 112813293.409 7 87743694.888 9 21133743.570 9
21870929.664 7 116953684.838 7 90963968.492 9 21870934.273 9
13 10 22 13 40 1.0000000 0 16G01G07G08G09G11G17G19G28G32R01R14R15
R16R17R18R24le
Keep going through the file. Use notepad to search for "MARKER" and then you'll figure it out.
you can email me the file at kristopher dot morgan dot 5655 at gmail dot com
Rinex Converter Is Wrong, Contact Trimble
From your file:
R16R17R18R24
The C2 column is fully populated which is wrong.
The P2 column only has data for satellites G01, G07 and G17.
G01 is a GPS 2F satellite, G07 and G17 are GPS 2R-M satellites. Those are the ones transmitting C2 signals.
Change the observation line to read:
5 C1 P2 L1 L2 C2 # / TYPES OF OBSERV
and resubmit.
Example
2.11 OBSERVATION DATA GPS(GPS) RINEX VERSION / TYPE
cnvtToRINEX 2.17.0 convertToRINEX OPR 22-Oct-13 14:00 UTC PGM / RUN BY / DATE
RTK-BASE_1 MARKER NAME
1 MARKER NUMBER
0220358249 R7 2.32 REC # / TYPE / VERS
TRM41249.00 ANT # / TYPE
-1777845.1124 -4513442.8048 4131357.2775 APPROX POSITION XYZ
1.5000 0.0000 0.0000 ANTENNA: DELTA H/E/N
2013 10 21 15 46 15.0000000 GPS TIME OF FIRST OBS
2013 10 22 1 13 30.0000000 GPS TIME OF LAST OBS
16 LEAP SECONDS
23 # OF SATELLITES
G02 1305 0 1303 1271 1271 PRN / # OF OBS
G03 386 0 383 360 360 PRN / # OF OBS
G04 820 0 818 762 762 PRN / # OF OBS
G05 1102 1097 1100 1097 0 PRN / # OF OBS
G06 586 0 584 563 563 PRN / # OF OBS
G10 947 0 947 925 925 PRN / # OF OBS
G12 1199 1198 1191 1198 0 PRN / # OF OBS
G14 313 0 313 289 289 PRN / # OF OBS
G15 1039 1039 1039 1039 0 PRN / # OF OBS
G16 288 0 288 205 205 PRN / # OF OBS
G17 513 509 507 509 0 PRN / # OF OBS
G18 985 0 985 976 976 PRN / # OF OBS
G19 201 0 195 143 143 PRN / # OF OBS
G20 12 0 10 0 0 PRN / # OF OBS
G21 1223 0 1222 1201 1201 PRN / # OF OBS
G22 675 0 675 668 668 PRN / # OF OBS
G24 971 971 971 971 0 PRN / # OF OBS
G25 1143 1138 1136 1138 0 PRN / # OF OBS
G26 823 0 822 801 801 PRN / # OF OBS
G27 497 496 493 496 0 PRN / # OF OBS
G28 229 0 229 175 175 PRN / # OF OBS
G29 1377 1377 1375 1377 0 PRN / # OF OBS
G31 2 1 1 1 0 PRN / # OF OBS
END OF HEADER
13 10 21 15 46 15.0000000 0 6G02G04G12G17G24G28
23204965.46915 -405649.45315 -275780.68856 23204962.45356
20767557.01617 -308968.62117 -215682.90658 20767554.84058
23737891.40615 23737889.89158 -381514.93815 -270786.83658
21035177.64117 21035175.13359 66390.33217 46366.12159
21613815.60217 21613816.51659 -223051.58217 -156379.04759
22653896.96917 116586.87117 84387.72357 22653893.30157
Loyal Is Correct, My Bad
I missed the fact that SurveyorConnect collapsed the blank spaces that should have been in the C2 column. As I look at the other saellites I see that the values in the C2 column are actually L1.
BTW Loyal, exactly how did you post that, there are times I post data and would like to see the blank spaces held?
Paul
I used the "code" option on the right hand side of the "message" page (to the left and slightly below the "smileys").
Click on "code" and select "code block"
Insert the text that you want to appear as in NOTEPAD, BETWEEN the middle brackets between code and "backslash" code.
This:
PROGRAM = datasheet95, VERSION = 8.3
1 National Geodetic Survey, Retrieval Date = OCTOBER 22, 2013
MR0820 ***********************************************************************
MR0820 FBN - This is a Federal Base Network Control Station.
MR0820 DESIGNATION - EVANSTON
MR0820 PID - MR0820
MR0820 STATE/COUNTY- WY/UINTA
MR0820 COUNTRY - US
MR0820 USGS QUAD - EVANSTON (1978)
MR0820
MR0820 *CURRENT SURVEY CONTROL
MR0820 ______________________________________________________________________
MR0820* NAD 83(2011) POSITION- 41 15 17.06617(N) 110 58 53.36028(W) ADJUSTED
MR0820* NAD 83(2011) ELLIP HT- 2126.629 (meters) (06/27/12) ADJUSTED
MR0820* NAD 83(2011) EPOCH - 2010.00
MR0820* NAVD 88 ORTHO HEIGHT - 2141.6 (meters) 7026. (feet) GPS OBS
MR0820 NAVD 88 orthometric height was determined with geoid model GEOID99
MR0820 GEOID HEIGHT - -14.91 (meters) GEOID99
MR0820 GEOID HEIGHT - -15.17 (meters) GEOID12A
MR0820 NAD 83(2011) X - -1,720,000.922 (meters) COMP
MR0820 NAD 83(2011) Y - -4,485,086.154 (meters) COMP
MR0820 NAD 83(2011) Z - 4,185,135.348 (meters) COMP
MR0820 LAPLACE CORR - 6.73 (seconds) DEFLEC12A
Becomes THIS:
MR0820 PID - MR0820
MR0820 COUNTRY - US
MR0820
As I understand the receiver was not moving during the logging of data. Remove these two lines:
2 1
or remove just one line
2 1
A GREAT BIG DUHHH?
"Start of Kinematic Data", staring us in the face.
Sometimes we dig too deep.
There might be line starting like
3 X
Where X is number of rows after this line. often MARKER NAME (NUMBER) is placed in one of those lines.ANTENNA: DELTA H/E/N is usually there too.
I would remove these records as well this whould make a nice static only Rinex file.
