Is there anybody who use convertor to convert from topcon, leica or sokkia total station's measurements files to jxl (jobXML file for Trimble)?
I use ASCII File Generator to convert to .jxl/.job files
https://www.trimble.com/globalTRLTAB.asp?nav=Collection-62098
T. Nelson - SAM
What field data collector software are you using? If you are using Survey Pro then .jxl can be exported directly from the data collector.
I'm not using it, but i try with no result, to convert from landXML to jxl. I converted raw topcon's file to landXML with Topcon link. On screenshot you can see on left landXML file and converted file jxl...
?ÿ?ÿ
The units between the two aren't compatible. On one side you're using grads, mmHG, and celsius. The output is different with a maybe South azimuth and grid angles increasing to the North-East. I'm sure the software can handle the conversions though. What was wrong with the first file ?
