old 5600 trick
11 Users
Illustrious Member Registered
@warrenward
One of those things, we all have done something similar, just have to go back and re locate the points.?ÿ
Posted : 18/11/2020 6:17 am
(@cf-67)
Honorable Member Registered
@notsomuch
A 3 pt angle only resection off distant towers or other landmarks that have known coordinates is one use I can think of.
Solar/Astronomic observations is another.
Posted : 18/11/2020 7:32 am
(@rover83)
Noble Member Registered
Posted by: @notsomuch
OK, I've got to ask: why would one store angles only without a distance?
There have been a few times where I couldn't get a good reflectorless return off of an object (usually a wire, or something at a very oblique angle), and was working solo. Tie it with the same point number from a different setup using "angles only", tell it to average the observations, and you'll get a 3D point at the averaged intersection of those angles.
It's pretty rare though, think I have done it maybe a handful of times in 15 years. And I always measure distances with resections...
Posted : 18/11/2020 7:39 am
(@warrenward)
@rover83?ÿ?ÿ you may be on to something - about 1/2 of these shots were end of white parking space stripe - which had never given me trouble before. but, the other half were solid concrete angle points which should give me solid distances -
the good news is that I took enough supplemental GPS shots that I can piece together this one area that is surrounded with good data (both GPS and Robot), but I am inclined to punish myself and return to the site and do it correctly - sort of an idiot trip - maybe I'll pay attention next time.
Posted : 18/11/2020 7:53 am
(@geopro_consultants)
Trusted Member Registered
@rover83 you do this in TBC? I've never been able to get that to work, though I thought it should.
Posted : 27/11/2020 8:30 pm
Share:
