Minor Annoyance
2 Users
I'm using Carlson Survey 2012 w/ Embedded AutoCAD; whenever I create a block, using the write block command, the block is scaled up at a factor of 12. I realize that this is probably caused by some kind of architectural function, but I can't seem to find where to change it.
Has anyone else run into this problem? How did you fix it?
It's pretty simple to change the scale, just annoying to have to do it every time....:pinch:
TIA
Radar
Posted : April 26, 2013 3:10 pm
Don't know about Carlson Survey, but I believe if you set you insertion units (INSUNITS) to zero ( 0 ), it might fix it.
Sounds like your insertion units might be inches.
Posted : April 26, 2013 5:24 pm
